timing....
Old Mar 28, 2011 | 10:14 PM
redneck sweetheart's Avatar
Default timing....
ok so today i finished up rebuilding the top end of my 7.3 idi if you remember i had the post "overheating my 7.3" anyways im having a timing issue... i think. when i stripped the motor down i pulled the injector pump off in one piece. and when i went to time it. i couldnt find it in the book on how i should.. i have done it once before but cant for the life of me remember how.... i lined up the timing mark on the crank with the top hole and set the timing pin at 6 o clock...... pull started it since i had to prime the fuel system.. hardly runs tons of white smoke runs for a few sec then looses power and stalls.. i know white smoke is fuel issues. so my guess was i timed it wrong. any suggestions?
Old Apr 10, 2011 | 12:45 AM
Sycostang67's Avatar
You took the IP off, was the IP gear still attached?
Old Apr 10, 2011 | 04:25 PM
DieselCrawler's Avatar
you have the IP 180* off. got 10 bucks on it.
quiksilver1j
Jul 30, 2015 12:41 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
jjbced
Oct 26, 2014 09:09 PM
