question on my 97 f-250 7.3
Nothing. If your pressure is droping now you can shim the FPR or go with electric fuel that would make it so the pressure wouldn't drop and you might gain 1-2hp depending on how much the fuel pressure is droping
You need to check your fuel pressure at the schrader valve on the side of the fuel bowl... You can use a tire pressure gauge. Just have a rag handy because it will spray a little. Do this while the truck is idling. Let us know what that number is.
You want right around 65-70 psi at idle... But you don't want to go much over that or you will start taxing the fuel pump heavily.
If it is below 45ish, you can shim the fuel pressure regulator with a bb and it will increase the fuel pressure.
Browe347
Dec 11, 2016 02:59 PM
Feb 18, 2015 02:40 PM
Browe347
Sep 30, 2014 11:35 PM
