5000 or 5500 rpm gsk
Old Mar 26, 2007 | 08:03 PM
smokey's Avatar
Default 5000 or 5500 rpm gsk
has anyone used or had experience with any 5000 or 5500 gsk. Where is a good place to get the springs?
Thanks in advance
Old Mar 27, 2007 | 12:15 AM
HOTMOPR's Avatar
Stock bottom end is only good for about 4500. From what I have heard. Maybe with a good balance job and a good dampener may get some more.
Old Mar 27, 2007 | 12:21 PM
smokey's Avatar
i am just looking for the extra fuel through the lower rpms. just want to know if they make a difference in starting, or any other thing like that.
thanks
Old Mar 27, 2007 | 01:36 PM
NukleusX's Avatar
smokey, what mods have you done so far? gsk should not be considered unless you have already modded other things such as your fuel plate, got bigger injectors, etc as far as i know.
other people will likely chime in; and if you HAVE done any other mods to your truck you should put them in your sig so people know what you are workin with-
Old Mar 27, 2007 | 02:20 PM
Racer9's Avatar
A 4k will do you fine, it'll fuel 'til about 4200, but you'll need exhaust valve springs.
Then a fuel plate, 4" exhaust, turbo....
How much more do you want to spend?
Old Mar 27, 2007 | 05:59 PM
smokey's Avatar
sorry about not writing everything in the sig I will fix that. the only reason i am asking is because I want all the fuel I can get (go big or go home) I am about to do lots of head work and get some twins, but it looks like maybe the 4ks will do. my truck has suncoast trans, guages, 4" exh, bhaf, no plate, mack plug, gutted afc, and soon to have a gsk, delivery valves, 435 injectors, stage 2 head, fire rings, studs, twins with hx35 top s400 bottom, water meth. and probably more later down the road.
thanks for the info guys
Old Apr 8, 2007 | 03:56 PM
oldsmokey97's Avatar
you will NOT want a 5k kit without having more air. These things get sooo hot sooo quick over about 3500rpms.
But if you gotta..... just get the 4k kit and you will be more than happpy.
Lance
Old Apr 26, 2007 | 10:01 PM
Crawler's Avatar
I have a 5K in my Little truck.
The 5K is WILD. I wouldn't recommend having a 5K done unless you are just going for stupid fuel. A 4K with the right setup can actually be tweaked to the mid 4's
The only way I would do a 5K is with the pump off of the truck and on a pump stand. Much easier to get it dialed in that way.
The 4K will have more than enough bottom end fuel for you, as long as you have the supporting mods.
~Wes~
BlueBell2000
Sep 10, 2015 05:33 PM
Taylor03
Jun 6, 2015 11:09 AM
InheritedDiesel
Apr 12, 2015 04:35 AM
Josh Chretien
Mar 1, 2015 06:00 AM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
