truck will not shift into gear
Old Mar 13, 2011 | 09:36 PM
codyawise's Avatar
Default truck will not shift into gear
my 97 5speed psd will not shift into gear and will not start without having to jump the starter.
lets see the best way to put it...
once i finally get the truck started in neutral. i have to yank and pull with all my might to try and get the truck and gear and still most the time will not go into gear i have very very minimal clutch pedal. i just replaced the slave cylinder bout a month ago because the o ring on the old one went. i have had people tell me to re-bleed the slave cylinder which i have and still no change.
so what i am wonderin is if its possible that it could be the pedals and the linkages under the dash are just worn out
any info would be great
Old Mar 13, 2011 | 10:26 PM
ccarrier's Avatar
check the pedal box for cracks
Old Mar 13, 2011 | 10:34 PM
prison's Avatar
is your clutch gone?
Old Mar 14, 2011 | 12:24 AM
97dieselnewb's Avatar
sounds like the clutch, was it slipping or shuttering at all?
Old Mar 14, 2011 | 12:20 PM
codyawise's Avatar
clutch is not the problem it does not slip at all i just put in a south bend clutch in this past summer and since then the truck has mostly highways miles
Old Mar 14, 2011 | 12:23 PM
any leaky cylinders? actually, come to think of it, I had a wheelin rig and the shift coupler broke, pop of your shifter boot, and take a look down there see if everything looks alright
Old Mar 14, 2011 | 12:37 PM
codyawise's Avatar
that wouldnt cause nothin with the pedal like i said i have very very minimal pedal and alot of play. it will shift perfectly fine without the truck runnin but once the truck is running is almost damn near impossible to shift into gear
No leaky cylinders or anything like i said i replaced the slave cylinder and when i looked the other day the reservoir was full
Old Mar 14, 2011 | 02:32 PM
Oh sorry, I am at work and on my phone, forgot about the pedal part when I replied
Old Mar 16, 2011 | 06:35 PM
codyawise's Avatar
i just got a call from my uncle sayin the truck is runnin perfect now since he replaced the pedals and linkages for me
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:27 AM
EverettsGMC
Mar 29, 2015 05:42 PM
aoutlaw95
Mar 3, 2015 09:02 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
