1990 1500 6.2l Diesel stalls while driving.
Old Feb 28, 2011 | 10:21 PM
fommy100's Avatar
Default 1990 1500 6.2l Diesel stalls while driving.
Hello,
Can anyone help me, i just bought a 1990 1500 6.2l diesel, after many days of work shes up a running and will idle for hours and run.
now while driving she will cut out, when it comes to a stop I can crank the starter and it will turn over very fast but wont fire up.
After getting the truck home on a tow truck you turn the key and she fires up straight away.
Any ideas?
Thanks in advance.
Old Feb 28, 2011 | 11:28 PM
2MuchJunk's Avatar
The first thing I would check is to make sure you have a good fuel filter. Then check to make sure your lift pump is running while the truck is running and that you are getting no air in the line.
Old Mar 1, 2011 | 11:07 AM
fommy100's Avatar
Default diesel stalling
I changed the filter with a new one and bleed the system...no air in the system...the lift pump was replaced with a new one.
Old Mar 1, 2011 | 05:36 PM
Crazy's Avatar
check your return lines for leaking
Old Mar 1, 2011 | 10:33 PM
fommy100's Avatar
Default 6.2l stalls
okay will check next time i take it out. i noticed that the battery terminal is loose on the positive on the passenger side. would that cause it to cut out?
Old Mar 3, 2011 | 08:39 PM
fommy100's Avatar
Default check return lines
Finally got around to looking at this truck again, okay the inlet line to the fuel filter was leaking, i also had a loses positive connection on the aux battery, and lastly I also pulled a code 33 off the computer.
anyone know what code 33 is?
Iam hoping that this will finally get this truck up and running.
Old Mar 3, 2011 | 09:25 PM
Crazy's Avatar
DTC 33 - EGR Control Pressure/Baro Sensor Circuit High
not sure what fix is for that
fuel will gave the stalling suck air and batteries also
Old Mar 4, 2011 | 09:44 PM
fommy100's Avatar
Default Map Sensor
switch the MAP sensor out with a new one, still comes up with code 33........some of the vacuum pipes are loses. It looks like the last owner mixed them all up.
Old Mar 4, 2011 | 11:29 PM
2MuchJunk's Avatar
The ecm on your truck does for the most part nothing. The only thing it does is run the cruse control and egr as far as I know and should have no bearing on how the truck runs. If you remove all of the lines and the vacuum pump at worst you should just have a check engine light that does nothing come on.
JohnFromVt
Aug 3, 2015 06:15 PM
Jan 5, 2015 01:40 AM
krinderhagen
Dec 31, 2014 07:12 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
thunderball52
Oct 6, 2014 08:08 PM
