Turbo Up grade??????
Old Feb 26, 2011 | 06:43 PM
KillStroker's Avatar
Default Turbo Up grade??????
I have a question. Is there a kit to keep you stock turbo and add another for a twin setup? Or is that dumb and should buy a twin set already setup? Can I do somthing to my stock turbo "Automatic" to increase boost fairly cheap? Or should i just get a single aftermarket one? I dont race my truck its a daily driver and I pull a trailer atleast once a week.
Also I see allot of people have other turbos other than the ones i normaly see like auroras garretts and bd what site can i go on to see other ones. Sorry for all the questions I cant be the only one I hope that would like this info. Thanks
Old Feb 26, 2011 | 07:29 PM
RAW's Avatar
RAW
I'm running a stock HX35 in my COMPOUND turbo set up.
To get more out of a HX35, or HY35, you can use a boost elbow or JHook. The cheaper route is to just plug the wastegate hose/tube.
Old Feb 27, 2011 | 07:50 AM
connermcpherson's Avatar
hahahah i like how you emphasized COMPOUND cause that is what it is, its not a TWIN setup cause there is one small turbo and one big turbo. NOT two small, or two big. I know some guys who have a hy35/hx35 as a "towing twins" setup. Mild power but still added power. Seems silly to me to run such a small setup, im more of a 66/98 guy
Old Feb 28, 2011 | 03:17 PM
Thanks Raw.. Where can I look to get a "compound" setup to utilize my existing HY35?
I guess you cant call them towing twins can you as you say cause a hx35 puts out more boost than a hy35 "its not a TWIN setup cause there is one small turbo and one big turbo"
Last edited by KillStroker; Feb 28, 2011 at 03:17 PM. Reason: Automerged Doublepost
Old Feb 28, 2011 | 07:11 PM
Mrfatsac789's Avatar
I would just buy a boost fooler for like 80 bucks. It keeps the waste gate closed for longer so that you get higher boost pressure. You can get a Quadzilla one that is "plug and play". Just plug it in and you instantly get higher boost pressure!
Old Feb 28, 2011 | 08:07 PM
RAW's Avatar
RAW
I happen to know a guy that made a set of compunds using his stock HX35!
https://www.dieselbombers.com/5-9l-2...urbos-2-a.html
Old Mar 1, 2011 | 06:53 AM
Looks nice Raw do you know where i can look for a kit minus the turbos to get something like that done? What would be the difference in a boost fooler and just getting the $3 Lowes J-hook Mod?
Old Mar 1, 2011 | 09:45 AM
01quadcab's Avatar
if you don't have a boost fooler you will throw over boost codes, but the boost fooler does nothing for keeping waste gate shut.
Old Mar 2, 2011 | 08:37 AM
The hx35 is bigger than the hy35 therefor the hy would be the primary. Not saying a agree with the setup just letting you know what people are running as a cheap budget twin setup.
Old Mar 2, 2011 | 11:03 AM
RAW's Avatar
RAW
Compounds will definitely have cooler EGT then a j-hooked HX or HY, and quicker spool up as well.
There are a few places that offer kits that utilize the factory turbos. Cheapest I found was $1800 though.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
