popping noise
Old Feb 22, 2011 | 02:40 PM
sitosterol's Avatar
Default popping noise
my dads truck is making a vibration noise upon acceleration from the drivetrain he said he cant tell where its comming from but there is no vibration in the steering wheel just the sound and an overal vibration in the truck. any ideas? he has replaced almost every part on the front end no in the diff though just steering and suspension. it get worse as he goes faster and less when he slows down. no squeeling just vibration. new tires as well just balanced
Old Feb 22, 2011 | 02:47 PM
1stgenman's Avatar
Did you happen to check the driveshaft for any unusual play in it and what about the front bearings? Finally can he fell any vibraton at all thru the seat?
Old Feb 22, 2011 | 05:58 PM
sitosterol's Avatar
yeah the drive shaft is still rock solid no movement. the front bearings on the spindle? those are brand new. dont know about the differential where the half shafts come out. the half shafts are brand new as well. yes its mostly in the seat and through out the truck no steering wheel movement but still a vibration in it. when power is applied it gets worse and when he slows down it gets better doesnt feel like its from the motor because it doesnt immidiatly go away when he lets off just when he slows down.
Old Feb 24, 2011 | 10:43 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Sounds like rear drive shaft U joints to me. The GFs dads truck had the same problem, I put two new ones in and it drove perfect. Is your shaft a one piece or two piece? If its a two piece then check for play in your carrier bearing.
Old Feb 24, 2011 | 04:36 PM
sitosterol's Avatar
carrier bearing was replaced 15000 ago. similer feeling but, he can hear it in the front end
Old Feb 26, 2011 | 07:38 PM
dmaxtothemax's Avatar
i wanna say there's u-joints between the transfer case and the differential on the front... i don't see why you would ever have to replace them, unless you used 4wd all the time... might be worth looking at tho
When my front hubs where going bad, it sounded like metal on metal when I speed up and slow down... You say you've checked or replaced all that tho...
Old Mar 2, 2011 | 10:16 AM
cfarley0210's Avatar
it sounds for sure like a u joint. did you jack the truck up to check the joint? i would lift the truck up and make sure it wont role any where and put it in neutral so you can spin the tires and really give those u joints a good checking. if you dont find anything there then i would rotate the tires and see if the vibration moves to the back of the truck
Old Mar 2, 2011 | 03:01 PM
1AMatt's Avatar
X2 on the tires. Not a bad idea to check them.
Old Mar 10, 2011 | 10:12 AM
1AMatt's Avatar
Any updates on what the noise was?
Boatman
Mar 20, 2015 10:00 AM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
chaoticape
Jan 4, 2015 05:35 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
