gas to diesel chevy
Old Feb 18, 2011 | 09:16 PM
green fuel's Avatar
Default gas to diesel chevy
i have a 2001, 1 ton 5.7 chevy express van with engine rod nocking . i was wondering if a diesel motor would fit the trany or should i find another van ?
Old Apr 6, 2011 | 08:43 PM
chevyhoss's Avatar
a 6.5 will
Old Apr 6, 2011 | 08:55 PM
Red_Rattler's Avatar
High Tech Redneck
Way too much work. You will need everything from dash cluster to computer to complete harness and locating a second batt in a remote location like the factory did. diesels had a th400 where as your 350 has a turbo350 trans, different drive shaft and the list continues...
Old Apr 6, 2011 | 10:44 PM
2MuchJunk's Avatar
As far as bolting up a 6.5 will bolt to the trans you have and to the motor mounts. In 01 all the trans. will be electronically controlled. Being a 1 ton if it has O/D it will most likely be a 4l80e which is what you would want but getting the weiring figured out to get everything working would be a nightmare unless you just want to gut the whole engine and trans and go with something older and rig everything else to work. I would ether fix what you have or buy a diesel van. No swap to a different engine is ever easy no matter what is said out there and some are worse than others and being you are trying to put a computer controlled engine in a different computer controlled van I would say this one would be on the worse side of that.
Angeliruo
Oct 8, 2015 08:24 PM
tilopa
Aug 21, 2015 03:19 PM
Beeman
15
Jun 27, 2015 06:59 PM
Snoobly
Dec 11, 2014 11:59 AM
Oct 31, 2014 06:10 PM
