Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
welding a plow cutting edge
Old Feb 13, 2011 | 09:22 PM
chevyhoss's Avatar
Default welding a plow cutting edge
i heard on a snow plow cutting edge you can add stick welds to the cutting edge to make it last longer. has anyone heard or done this if so what does it do does it work is it worth it thanks
Old Feb 13, 2011 | 09:28 PM
Uncle Bubba's Avatar
That would be a lot of grinding to keep it sharp and the cost of the grinding wheels would offset any money savings here I would think. But ya a good stout stick welder with some thick diameter stick would make a good hard weld. Wouldn't be as hard as the original blade material since it's case hardened steel but it would work.
Way to much work to be worth while if your time is worth any amount of money to you. In my opinion anyway.
Old Feb 13, 2011 | 09:35 PM
Captain Call's Avatar
You mean like hardfacing on a bucket of a hoe or loader?
Old Feb 13, 2011 | 09:38 PM
deck60's Avatar
you have to use hard surface rod
Old Feb 13, 2011 | 09:44 PM
Red_Rattler's Avatar
High Tech Redneck
Not worth the time and effort IMO...
Old Nov 11, 2011 | 05:29 PM
roaddog51's Avatar
HI guys i think this would be worth the time and money as a new cutting edge is way more expensive than the rods.. Did this to mine, welded a beed across the bottom edge about a half inch high it wore up to the weld and then stoped. i also weleded the bottom of the skid shoes and this also stoped the ware. BUT YOU MUST USE A ROD THAT HAS SOME NICKEL ALLOY IN IT.. i do a lot of plowing up here in the snow belt of northwest indiana and it lasted a realy long time hope this helps Thanks Guys....
Old Nov 17, 2011 | 09:19 PM
crzycummins's Avatar
a new 1/2" cutting edge for an 8 foot plow is only around 160 bucks and should last a few seasons depending on usage
justinsbeck
Jan 18, 2016 12:15 AM
Kfohne21
For Sale
Dec 23, 2014 04:17 PM
somarillw
Dec 8, 2014 09:07 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
