Vacum Pump/Wastegate Actuator
Old Feb 13, 2011 | 06:22 PM
jasonduke5's Avatar
Default Vacum Pump/Wastegate Actuator
Ok i dont hace enough vacum. Now here is where i am at. Should i Replace the vacum pump and go from there. I would replace it in a heart beat if i knew the Wastegate Actuator was good. I was wondering if i should put a manual Wastegate Actuator. I just know my luck i will replace the pump and the Wastegate Actuator will ve bad also. I know the pump is bad for sure. At idle when i start it i get about 7 in pounds if i m reading the gauge right. And when the truck warms up it drops to like 3 or 4 inch pounds. Like i said if i m reading the thing right first time useing one. But it drops from 7 what ever to like 3 or 4 what ever. I think the Wastegate Actuator i have now is good because when i move the Wastegate Actuator arm it sucks throught he Wastegate silonoid and if i pulg the vacum line with my finger and move the arm it olds the same amount of vacum. So what should i do
Old Feb 13, 2011 | 09:12 PM
Crazy's Avatar
ok when test vacuum pump there should be at least 22 in all the way to waste gate if you get 22in to the wastgate sol and you get hole lot less to wastgate it self then you have bad wastgate sol
Old Feb 14, 2011 | 06:16 AM
jasonduke5's Avatar
I tested it at the pump so i know i dont have enough to sol better yet the waistgate. What i m asking is should i start by replacine the pump or just go to a manual Wastegate Actuator. My luck is i will replace the pump the the sol will be bad then i will replace that then the Actuator will be bad and i will have hundreds into getting the turbo working right. Or would i be better off just going to a manaul Wastegate Actuator. If it is better to have the vacum i will go that way also it will just cost more
Old Feb 14, 2011 | 07:44 AM
Crazy's Avatar
i lust did away whit my vacuum pump and wastgate this weekend i like the TM boost is there when you need it if you go that way you will see the diff think it cost me $2.80 make it i some stuff all ready hanging around all did cost me $25.00 for belt so $27.80 compared $200.00
Old Feb 14, 2011 | 10:10 AM
jasonduke5's Avatar
I m kinda confused. you did away with the Wastegate. What i think if i understand it you made a manual Wastegate Actuator. I have seen on here some where that people make there own. I just couldnt find that page again. I found one from HEATH for 109 bucks. that isnt to bad. If i find the page on here again i might try to build my own. i afraid if i build my own i might have problems with it.
Old Feb 14, 2011 | 10:43 AM
Crazy's Avatar
here a site i went buy i did fine the spring was stiff enough so went up stiffer spring and it work out nice think it was #64 spring at ace hardware
Make Your Own Mechanical Wastegate Controller
Old Feb 14, 2011 | 01:30 PM
jasonduke5's Avatar
Thats awsome i m going to try that tonight i hope. the only thing i am unsure of is at the bottom it says about a boost fooler. What is that and do i have to worry about it. Thanks again Crazy your a life saver
Old Feb 14, 2011 | 02:08 PM
Crazy's Avatar
remember make sure you have boost and egt gauge before doing this mod
no you will not need boost fooler if you run no more 10psi boost anything over that yes you need a chip or a boost fooler
Old Feb 14, 2011 | 02:18 PM
jasonduke5's Avatar
i have a boost gauge but whats a egt gauge. i looked some #64 springs and they have a ton of then all the way from .013 inch pounds up to like 34 inch pounds. what for inch pounds should i look for in the spring. I thought all #64 springs would be the same
Old Feb 14, 2011 | 03:07 PM
Crazy's Avatar
#64 was just ace hardware the spring was 1"x 3 3/4
EGT is for exhaust temps
