02 Dodge 24 valve surges with no throttle response
Old Feb 10, 2011 | 12:26 PM
diddydoc2's Avatar
Default 02 Dodge 24 valve surges with no throttle response
This dodge has me against the wall. It shows no codes, fuel pressure after the filter is 3-6psi steady. It has been conerted to having the lift pump in the tank. It starts and drives ok but suddenly it will have no throttle response at around 1700-1900 rpm. Back out of it and get back into it and it is ok for a while then the same crap starts all over again. Fuel filter is clean and I found no air bubbles in the fuel. Any ideas would be a help.
Thanks ahead of time.
Old Feb 10, 2011 | 12:29 PM
Default Re: 02 Dodge 24 valve surges with no throttle response
Sounds like your VP44 is starting to go.
Old Feb 10, 2011 | 03:16 PM
cummin_un_glued's Avatar
FormerVendor
Your lift pump should be making 15psi at idle...the vp44 will not pull fuel thru the in tank lift pumps like it will the carter pumps on the side of the block...you will have to change the pump in the tank, convert it back to the carter pump on the side of the block, or put an aftermarket pump on it like an airdog or fass....but you do NOT need a vp44 unless you fix the fuel pressure and check the voltage at the injection pump and you still have this same problem
also if you go back to the lift pump on the side of the block you will have to remove the in tank pump or the new lift pump will not pull fuel thru it and you will still have a pressure problem
Old Feb 10, 2011 | 06:57 PM
chadcycle 2500's Avatar
Also check trottle position sensor
Old Feb 11, 2011 | 09:47 AM
GuyWithA24Valve's Avatar
Everything Cummin_un_glued said
Old Feb 11, 2011 | 11:06 AM
FormerVendor
Any word on ur problem?
Old Feb 11, 2011 | 11:42 AM
Bet way to remove the intank pump is by using a Vulcan Draw Straw V.
Old Feb 11, 2011 | 02:17 PM
FormerVendor
Of course then u would have to replace the fuel line all the way to the new lift pump on the side of the block.........or you could simply take the pump out of the module and just replace the plastic hose. That went to the pump with a new longer one angle cut on the end long enough to touch the bottom of the cup..........then you still use all of the factory fuel line
jeremiah1
May 19, 2016 04:58 PM
12vWoodHauler
Sep 30, 2015 07:58 PM
jeremiah1
Jun 18, 2015 05:01 PM
rusty 6.5
Jun 13, 2015 05:45 PM
PeteBug
Jun 11, 2015 12:16 PM
