solving the head gasket problems with the 6.7
Old Feb 8, 2011 | 04:19 PM
coors_man_2005's Avatar
Default solving the head gasket problems with the 6.7
just wondering what others have done on the head gasket issues im fixing to change mine for the 3rd time i have 625 studs had the head re surfaced and all the goodies this time i am going to add a ewg for sure but what else thanks for the imput everyone
Old Feb 8, 2011 | 11:35 PM
kmkdiesel's Avatar
get rid of the smarty , the ewg would be the first step in doing this, I am getting ready to put in the prototype head gasket i have to see how it holds up, going to run it with the mightey diesel head bolts, which are better then stock but not as good as arp 2000s. Everyone is dead set on 625s and thinking it is a fix but there has been numerous people blow gaskets still running 625s, I think the gasket is the weak link for sure, and once a better gasket gets made it will fix the problems, if not or until then it seems an ewg is the only fix and keep the drive pressure no higher then 45-50 psi with the stock turbo
Old Feb 9, 2011 | 02:46 AM
dodgeram082500's Avatar
I am not going to say either way on the but smarty is not the only cause of blown headgaskets on our trucks I have blown mine 2 times both times I had H&S tuning on it ,but as nic said here egw with help ,but it wont fix it for sure (last time I blew mine I had studs, egw and a larger turbo on the truck). Nic is also correct on the 625s although I'd rather have them than the 425s personally anyhow my point being studs will only fix some of the problem. Drive pressure is only some of the problem. cylinder pressures in these things are insane. Nic is pretty much right on the money WE NEED A BETTER GASKET
If it where me I'd do some serious thinking about my final goals for the truck and pull the trigger on a stouter gasket.
Anyhow not trying to **** on anyones boots but just my .02
Old Feb 10, 2011 | 01:10 AM
DieselgodND's Avatar
is it really blowing the heat gaskets? or is it blowing in bubbes in the puke tank and then pushing out of the puke take on the drivers side of the engine ? just wondering guys let me know thanks
Old Feb 10, 2011 | 08:27 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
yep pressure in the rad. into the overflow tank. head gasket leaking
Old Feb 10, 2011 | 03:59 PM
On my last blown gasket I had delambination between 4 cylinders so in short answer they are actually blowing
Old Feb 10, 2011 | 06:15 PM
kmkdiesel's Avatar
here in three weeks I should have my prototype head gasket installed, I am going to install it with the mighty diesel head bolts, and thats it. i am going to install a drive pressure gauge and watch the drive pressure on it, but I am not installing a ewg. i am thinking the gasket is the weak link here and with a different gasket 625's and ewg will not be needed. The mls gasket works fine on the 5.9s but not on the 6.7s, I think with a different gasket, and arp 2000s or the mighty diesel head bolts no one will blow agasket on a moderate modded 6.7. I dont think my gasket is gone yet, but it does show sure signs off leaking every once in a while.
Old Feb 11, 2011 | 07:22 PM
thanks for the imput i hope we can get these things sealed up mines not completly blown yet but it is seaping for sure it fills up the puke tank and heater quits workin every once in a while to cold for that crap and got hot on me once so its comin i just want to get the right parts here before it happens and mayb this will be the last time to fix it but my luck dont run that high and who is makin your gasket kmk
Old Feb 11, 2011 | 08:12 PM
cummin_un_glued's Avatar
FormerVendor
has anybody tried fire rings made out of something other then stainless steel?...not sure what one would use...fire rings stop the problem but on a street truck your lookin at changin the rings around every 30k miles because they will break....if someone could come up with a material that would stand the heat yet stand the heat cycles i think that would be the ticket
Old Feb 11, 2011 | 10:07 PM
i think garret at pure diesel power fire ringed his guessing with stainless and when i talked to him a few months ago he said his tried leaking on him but he retorqed and was fine after that but dunno about anymore but thats just the only one i know of
