6.2
Old Feb 8, 2011 | 02:50 PM
94cummins12v's Avatar
Default 6.2
ok im looking at a 82 chevy with a 6.2 diesel automatic any good news? any bad news? could i turbo it withought doing anything to the tranny mainly looking at it for a wood hualer
Old Feb 8, 2011 | 03:34 PM
Crazy's Avatar
If you going turbo it think you going have to go with 6.5 heads and injectors cause injectors mount diff from 6.2 sure someone charm in on it
I take it got the 700R4 trans don't know how that hold up for what you want to i would think about the 4L80e trans
Old Feb 8, 2011 | 04:01 PM
well if i were to go to all that trouble ill just get a 7.3 non turbo and throw a turbo on it
Old Feb 8, 2011 | 04:09 PM
crawley's Avatar
just put 6.5l exhaust manifolds mont the turbo, and add the 6.5l intake. after running the oil line from the back of your 6.2 oil senser and drilling a hole near the top of oil pan for retrun. your done as long as you don't have A/C turbo won,t clear a/c box!
Old Feb 8, 2011 | 04:39 PM
Crazy's Avatar
i like said wasn't if 6.2 head would work turbo or not glad someone jump in
i gave you wrong info you will have run 6.5 injectors they are shorter then 6.2 the 6.2 be to closet the the turbo and return lines and Crawley cover the oil lines
Sorry just wasn't think right got bad head cold going on
Old Feb 8, 2011 | 05:20 PM
2MuchJunk's Avatar
1982 would most likely be a th400. As far as I take it and how it looks to me you could just put the manifold of a 6.5 turbo on a 6.2 but would not be able to remove the injectors without removing the manifold. The easiest thing to do if you are that worried about it would be to find a exhaust manifold and see it will fit. If the engine is original it will have coarse thread and all 6.2's and 6.5's after 82 have fine thread. At worst you could make a spacer to go between the head and manifold.
Old Feb 8, 2011 | 11:37 PM
SquirrelCrusher's Avatar
If all you wanna to do is have a wood getter, a turbo might not be needed. Adding a turbo isn't super hard though. Just got to find an engine to steal parts off of.
NSmachine44
Aug 16, 2015 09:25 PM
MIBoondocker
Jun 20, 2015 11:56 PM
jedder21
Mar 7, 2015 09:47 PM
Caveman94
Dec 8, 2014 12:21 PM
jdcarter
Nov 29, 2014 11:31 AM
