OM617 repower vacuum questions
Old Feb 8, 2011 | 02:49 PM
Walkenvol's Avatar
Default OM617 repower vacuum questions
Does this agree with what you have done on your jeeps?
Old Feb 8, 2011 | 03:07 PM
Walkenvol's Avatar
Also curious as to what you guys did with the temp sensors?
Attached Thumbnails OM617 repower vacuum questions-btybxl.jpg   OM617 repower vacuum questions-wmyyzl.jpg
Old Feb 8, 2011 | 07:43 PM
jeep-dsl's Avatar
I dont think you should remove vacuum stuff you pointed to. I know it reduces the amount of vacuum somehow. I will try to find a thread I read about it. I left those sensors in but neither are hooked up now. The H20 sensor is near middle of block by the Injection pump. I never saw an OM617 that clean.
Old Feb 9, 2011 | 06:55 AM
Walkenvol's Avatar
I've been surprised as from your pictures it appears you perform the swaps without washing off the motors. Only takes a cheap spray can of engine cleaner, a pressure washer and 15-20 minutes. I do it while its still hanging on the cherry picker. Sure keeps the hands and clothes cleaner.
Old Feb 9, 2011 | 10:18 AM
deck60's Avatar
I am also a member of benzworld here are some pictures from them on vacuum actual diagrams if you have issues got there they are true benz I hope the uploaded
Attached Thumbnails OM617 repower vacuum questions-vac.jpg   OM617 repower vacuum questions-vac1.jpg   OM617 repower vacuum questions-vac2.jpg   OM617 repower vacuum questions-vac3.jpg   OM617 repower vacuum questions-vac4.jpg
Old Feb 9, 2011 | 10:40 AM
deck60's Avatar
Vacuum Diagrams...can i get the right one? - Benzworld.org - Mercedes-Benz Discussion Forum
this link has loads of pictures
Old Feb 10, 2011 | 06:44 AM
Walkenvol's Avatar
Thanks deck60 - any way to access the pictures a little larger as I can't read them even after clicking on the thumbnail.
What have you guys done successfully who have repowered toyotas and jeeps with manual transmissions? Seems like almost all of the vacuum stuff can leave other than the shutdown switch?
Old Feb 10, 2011 | 10:58 AM
deck60's Avatar
yes pm me your email and I will send you directly
I have lots for mb stuff for these engines I found a place that you can buy anything for these engines reasonably priced you need to be aware benzworld these guys are true stock no mods kinda boring to me they even argue about factory batteries versus aftermarket they do have a wealth of info they know these engines inside upside down and backwards they are just all about the stock I posted on there about my s10 mod and they wanted to know why I wasn't fixing up the old car god bunch just stock nuts
Old Feb 10, 2011 | 11:41 AM
Walkenvol's Avatar
Thanks - PM sent.
I follow peachparts and there is a lot of knowledge there also. Nobody's flamed me there yet on my repower questions.
Old Feb 10, 2011 | 12:52 PM
deck60's Avatar
yea I hear you they are a great wealth of knowledge just all oem factory no thinking outside the box on here we threw the box in the fire and torched it
your email is on it way I do have a factory oem sitting in garage if you have any questions and I have made my own injector tester and prechamber puller
