tanny build up
Old Feb 4, 2011 | 02:03 AM
redneckcummins85's Avatar
Default tanny build up
so ive done a good amount of work under the hood, not a crap ton but enough, now i need ideas on how to build my stock tranny up. piece by piece, how would someone begin to rebuild these crappy dodge tranny's???? valve body, what kind? torque converter,what kind? etc... i have the auto tranny... with my tax return would like to start buying pieces to rebuild it when i get home from korea next year. thanks guys.
Old Feb 6, 2011 | 03:28 AM
bump
Old Feb 6, 2011 | 03:34 AM
dukeboy_318's Avatar
i would start with at least a valve body, then get a deep sump pan for now, when you get the cash, pull the trans, have it rebuilt with stronger clutch packs to eliminate the slipping as much as possible(this is what creates heat, heat cause the trans to die) and depending on how far you want to plus hit power wise will determine the next step. I go by what hp and torque you want and then add at least 30 percent in order to give you some growing room. If youre going for 400 plus hp and 1000 ft lbs plus, id go ahead and swap in billet input and output shafts and maybe even the intermediate shaft. Get at least a 3 disc converter and that shoudl get you started. another safe bet is to call a trans plac lik ATS or Suncoast, tell them what you have and what your plans are and see what they reccomend. They are the experts, its their field
Old Feb 6, 2011 | 07:32 AM
sweet deal..thanks dukeboy!
bigbadDT
Diesel Engine Conversions
Aug 28, 2017 06:36 AM
redveloce
38
Jan 22, 2017 03:55 PM
DODGEARMYGUY
Feb 8, 2015 07:08 PM
jtwthaxj
Jan 14, 2015 06:52 AM
Oct 15, 2014 12:30 AM
