raptor fuel pump and lines?
Old Feb 3, 2011 | 11:58 AM
arobertson's Avatar
Default raptor fuel pump and lines?
so if i do a raptor 150 and 1/2" lines should i do a upgraded draw straw? im doint the banjo bolt upgrade on the injector pump aswell
oh and is it just a banjo bolt upgrade or is it a new fitting like a 90 that screws in?
Old Feb 3, 2011 | 12:59 PM
tburke's Avatar
I did the Vulcan Draw straw and Big line kit that goes from the canister to the injection pump. Works very well.
Old Feb 6, 2011 | 09:06 AM
connermcpherson's Avatar
If u got the knowledge, do a sump instead so u dont run into the 1/4 tank crap. No matter what anyone says, u still run into the 1/4 tank fuel problem with a Draw Straw.... the sump eliminates that problem
Old Feb 6, 2011 | 09:23 AM
RAW's Avatar
RAW
I have the Vulcan Draw Straw V. and don't have the 1/4 tank issue. I don't even have a 1/16 tank issue! I thought about a sump, but I don't need an extra 2.5" protrusion out the bottom of my tank.
DrawStraw™ V HiFlow
Old Feb 10, 2011 | 08:34 AM
I used the original Vulcan draw straw and on 1/4 pass boost launch the fuel would shlosh so much that sometimes i would loose fuel pressure becuase there was no fuel so this time around immma do a sump. I was worried about protrusion to cause im a lowered 2wd so imma heat and bend a piece of steel around the sump to protect it from the elements
Dbleo351
Nov 20, 2016 09:34 AM
HardLuck
Jun 24, 2015 08:04 AM
Wigginsmk
10
Jun 2, 2015 08:06 AM
ninetyoned250
Mar 1, 2015 09:10 PM
moneypitk5
Feb 12, 2015 11:01 AM
