04 Duramax LLY p0700 Trouble code
Old Feb 2, 2011 | 05:38 PM
DuramaxMann's Avatar
Default 04 Duramax LLY p0700 Trouble code
I was driving along about 45 and I was in 4th gear and my Allison must have slipped because I was stuck in 4th gear it would not shift up or down its an auto and when I parked and put it in park and when I went to put it in reverse its wouldnt go then about 4 hours later I was able to go through all gears then the check engine light went away only after i heard a small clunk or knock of some sort and then I took it to NAPA and had the code read and it said it was a something about the external shift solenoid. And it just happened again help.
Old Feb 2, 2011 | 05:54 PM
BriteWhiteRam's Avatar
Code: P0700
Modules: ECM, TCM
Description: Transmission Control Module (TCM) Requested MIL Illumination
Limp mode??
Old Feb 2, 2011 | 06:07 PM
I guess it did go into limp mode. Oh and just so everyone knows the tranny fluid to good.
Old Feb 2, 2011 | 06:20 PM
it could be your NSBU(neutral safety back up) switch as well
Old Feb 2, 2011 | 07:13 PM
Ok im takin it to a auto shop that specializes in transmissions we'll see.
Old Feb 3, 2011 | 01:27 AM
TruePerformanceDiesel's Avatar
FormerVendor
Is your P R N D display the correct gear? That would be right on track with BriteWhiteRam.
Old Feb 3, 2011 | 02:00 AM
I have the edge cts monitor and it tells what exact gear its in. I dont know much about trannys so be patient with me.
Old Feb 3, 2011 | 02:26 AM
toughtrucks's Avatar
I have the same problem with my truck and it turns out the speed senser is going bad. mine only does it when it is below 50 deg outside and when i put the prograhmer in.
Old Feb 3, 2011 | 02:28 AM
FormerVendor
Okay, the factory display in the dash. Heres a write up we did on the NSBU switch.
Old Feb 3, 2011 | 03:10 AM
Thank you so much TPD looks like even I could figure out how to replace the nsbu. Giving I know nothing about trannys do you think a normal person could do this.
Toughtrucks funny you should say that cuz everytime its happened to me its been below heck even 40 degrees. But it did do it once before I got the edge juice w/attitude.
Last edited by DuramaxMann; Feb 3, 2011 at 03:10 AM. Reason: Automerged Doublepost
dc2188
Sep 5, 2015 10:41 AM
robbyS
Apr 16, 2015 02:22 PM
duramaxtuner
Chevy/GMC Duramax 04.5-05 LLY
Apr 15, 2015 11:39 AM
Bighouse
Apr 9, 2015 06:51 PM
Oleoleson
Chevy/GMC Duramax 01-04 LB7
Mar 28, 2015 06:20 PM
