Wheel Spacer?
Old Feb 2, 2011 | 03:48 PM
Jasontx's Avatar
Default Wheel Spacer?
I just installed a pro comp 6inch stage 2 long arm lift kit on my 2007 2500 Mega cab. Im running 37/13.50/22 (toyo tires).
Long story short my tire rubs on the upper control arm. And i was thinking about putting a 1 inch wheel spacer or something? What do yall think about that and where can i get them and what do i need to buy? Or does it have to be an inch or less?
Thanks
Old Feb 3, 2011 | 09:15 AM
biged681985's Avatar
alot of people frown upon wheelspacers because they will cause premature wheel bearings failure. but for looks, a set of wheel spacers will make it look bigger
Old Feb 3, 2011 | 10:44 AM
u2slow's Avatar
I think about 3/8" is the max you can go with a simple plate spacer - maybe a touch more depending on your wheel stud length and wheel thickness (lugnut thread engagement). Then you jump up to about 1-1/2" where the spacer bolts on, and has its own studs.
Keep in mind though, the further you space the wheel out, the larger the steering radius, i.e. more likely to hit the front and rear of the wheel opening when steering hard over.
Old Mar 13, 2011 | 12:21 AM
ttam07's Avatar
im getting all of my stuff done up by these guys
TXPRO 4X4 - Home
call this number 512-564-1191 and talk to kevin he'll be able to help you out really experienced andgood prices as far as me im getting 1" wheel spacers for the 38-40s that im puttig on most people would agree but when you have to make a 6 point turn to get out of a parking-lot its a pain in the *** and wheel spacers definatley do help out
when you do talk to him tell him matt reed sent you to him...
good luck
Old Jul 4, 2011 | 05:24 AM
muffinman944's Avatar
These are what you want. They are wheel adapters that have the same lug pattern as what they bolt to. Thicknesses 2'' and under usually require you to grind down the original lugs.
cutthroatxxx
Jun 22, 2015 10:16 PM
6.5dieselman
Feb 26, 2015 04:45 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
94ifs
For Sale
Oct 23, 2014 01:35 PM
