Off Roading Diesel Discussions of Off Roading , Set Up , Designs , Practices , Techniques , Tips Including Trail Riding , Rock Climbing , Mud Bogging And More
jumping out of 4wd
Old Feb 1, 2011 | 02:24 PM
TX Farrier's Avatar
Default jumping out of 4wd
My 07 keeps jumping out of 4 hi and will not go in to 4 Lo at all I can hold it in hi but if you turn or put any pull on it it jumps out if I hold it in it works great help please
Old Feb 1, 2011 | 02:32 PM
Whit's Avatar
Site Mascot
is this a push button operation or is it an actual lever
Old Feb 5, 2011 | 07:59 PM
TX Farrier's Avatar
Lever
Old Jul 21, 2011 | 05:11 AM
Dr. FeelGood's Avatar
Buddy of mine had a similar problem, his rails were torqued a bit. He straightened them out and all was good.
Also had yet another friend with a '06 with the same type of problem his T-case needed a master rebuild.
Old Jul 21, 2011 | 06:13 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
my 08 has something wrong with it too. if i dont miss my guess it has a broken shifting fork.
Old Aug 13, 2011 | 04:53 PM
KingCopa's Avatar
you might want to check to see if the lever is adjusted right. I know on my Jeep it would do that and I would have to climb under and readjust the rail from the shift lever that goes from inside the truck to the tcase itself. Its free to check, also check to make sure your tranny mounts are good. if they are sloppy the tcase could be moving under load causing it to come out of 4hi but this shouldnt effect it not going in to 4lo.
Flikkie2001
12
Aug 29, 2015 10:03 PM
2gCummins
Jul 22, 2015 11:34 PM
MO.CA. Cummins
Apr 7, 2015 05:47 PM
mw1095mw
Jan 4, 2015 11:06 PM
lifted07sierra
Nov 24, 2014 10:22 PM
