Engine Code Problem
Old Jan 27, 2011 | 06:47 PM
Team01's Avatar
Default Engine Code Problem
I have a 1999 Ford F350 with 7.3 w/ turbo. I have two problems First one is that the service light can on and had it checked and the code is 1396. I just had the glow plug relay replace a couple days ago. What can be the problem? Second problem I have no power when I pull my LQ Horse Trailer can some one please help.
Old Jan 27, 2011 | 07:51 PM
CSIPSD's Avatar
https://www.dieselbombers.com/ford-p...ble-codes.html
Check here...
Do you have a glow plug relay or a glow plug controler?
As far as power goes, what mods if any have you done to the truck? How many miles? When was the last time you changed the fuel, air filters?
Old Jan 27, 2011 | 08:48 PM
Team01's Avatar
The truck has a glow plug relay. The truck has 176,000 miles on it . The truck is stock there has not been no mods done on the truck. The air and fuel filter was changed about 1000 miles ago.
Old Jan 27, 2011 | 09:07 PM
CSIPSD's Avatar
The code you gave is for a Left Glow plug bank, there is only one way that code should come up and thats with a glow plug controler, not a big deal, but something is strange there.
Take a look at all the boots and up pipes for leaks. You make have a boost leak.
Old Jan 27, 2011 | 09:23 PM
Team01's Avatar
I have replaced all the boots on the truck last month. What up pipes do I look for leaks. If the truck has a glow plug controler were is it located .
Old Jan 27, 2011 | 09:36 PM
FNJOLLY's Avatar
we had the same problem with our work truck with the 7.3 it ended up needing all new wirining harness but the harness on the tranny is wot was causing the main problem that and a bad pcm
Old Jan 27, 2011 | 09:38 PM
CSIPSD's Avatar
Glow plug controler would be on the passanger side of the motor, between the Cold side IC pipe and the AC compressor. Its in the same location as the Glow Plug Relay. Relays are round, the controler is rectangular.
Go back and check that all the boots are tight, and none have slipped.
The up pipes run from the exhaust manifolds to the back of the turbo. Up at the turbo there are two expansion slip joints that over time can start to leak leading to a low power condition.
Old Jan 27, 2011 | 09:40 PM
CSIPSD's Avatar
We are a long way from a wire harness right now...
Old Jan 27, 2011 | 10:46 PM
FNJOLLY's Avatar
if your harness,s are messed up it will send false codes
just a thought wldnt hurt to check out cause ours was reading camshaft controll sensor injectors and exhaust
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
klein444
Jun 20, 2015 11:48 PM
moneypitk5
Feb 12, 2015 11:01 AM
hunt4beer
Nov 15, 2014 09:06 AM
