another 19.5 question
Old Jan 25, 2011 | 08:06 PM
rednekroper05's Avatar
Default another 19.5 question
ok well ive looked at other threads and have quite found the answers im wanting so here i go.
ok are there any direct bolt on alum 19.5s that i can run? i dont want to run steelies on the inside.
secondly if there are not any wheels that will work could i put longer studs on it to be able fit the extra thickness of the alum. wheels
Old Jan 25, 2011 | 08:24 PM
Whit's Avatar
Site Mascot
I have them
Rickson wheel has direct bolt ups
I run the steel wheels but they have aluminum ones too
I use the liquid balance and no wheel weights
over 100k per set of tires
currently have the 265 version the first set was 285
goodyear G124
Old Jan 25, 2011 | 08:33 PM
well im looking for a way to run 6 alums and must companies say that you must run a steel wheel on the insides
Old Jan 25, 2011 | 08:37 PM
Whit's Avatar
Site Mascot
here ya go
Rickson Wheel Manufacturing
Old Jan 25, 2011 | 08:44 PM
Uncle Bubba's Avatar
Rickson doesn't offer the aluminum rims anymore as far as I know. I have them on my truck and even loaded heavy, I've never had any issues so I don't know why they don't why they discontinued them.
For guys that don't haul over weighted they were the best option. A good compromise between the heavy rated tires and the heavy steel wheels. Aluminum is significantly lighter weight per corner then the steel ones.
Old Jan 25, 2011 | 09:09 PM
Whit's Avatar
Site Mascot
each of my tire/wheel combo weighs in at 172 ea
Old Jan 25, 2011 | 09:49 PM
thats kinda my whole issue is the weight because forged alum rims should be able to handle the heaviest loads that I will ever put on it
Old Jan 25, 2011 | 09:51 PM
Whit's Avatar
Site Mascot
aluminum has to be 3x the thickness as steel for the same strength
Old Jan 25, 2011 | 10:35 PM
NoPlugs06CTD's Avatar
Yes, you CAN buy longer lug wheel studs and put them into your hubs. Google/bing search 'lug nuts' and several of those that sell lug nuts also sell the longer lug studs.
As far as running two alums on the rear, you would need to know the thickness of what you wanted to run to determine the stud length. There have been people who put two alums together in the rear, maybe someone who has them would let you know which wheels that will do that??? Not all alums can be faced together from what I have read.
NP
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
torg73
May 11, 2015 03:08 AM
Josh_L
Apr 12, 2015 12:12 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
