1998 Ram 3500 24valve Tps help
Old Jan 23, 2011 | 11:38 AM
Tkitt21's Avatar
Default 1998 Ram 3500 24valve Tps help
ok I have a 1998.5 dodge ram 3500 24valve 2wd automatic and im trying to replace the tps because when you get on it hard the truck sputters and cuts out. also its like the Torqconverter doesnt wanna lock up when im going highway speeds. so i hooked it up to obd2 and it threw the tps code But I cannot find where the tps is on the truck, so if someone could help me locate it and let me know if the tps could be causing the Tcc to not lockup that be great.. thanks in advance
Old Jan 23, 2011 | 01:34 PM
ffemt44169's Avatar
The TPS or the APPS is located on the front of the engine left side. Follow your throttle cable from the firewall. Its located just above the VP44.
Old Jan 24, 2011 | 01:02 AM
Tkitt21's Avatar
found it, thanks. my buddy let me take his old one off his wrecked 24valve and we replaced mine with it, it still sputters and cuts out when i get on it but it seems like it has more power now...itll black smoke now...idk whats wrong with it :/
Old Jan 24, 2011 | 02:01 AM
Red_Rattler's Avatar
High Tech Redneck
Have a fuel pressure gauge on it?
Old Jan 24, 2011 | 02:53 AM
Tkitt21's Avatar
No fuel pressure gauge, there is a dealership sticker under the hood saying the pcm was flashed due to erratic tcc lockup in 2000 so idk if the tcc is bad or what?
Old Jan 31, 2011 | 08:47 AM
celticnonic's Avatar
Is it still giving the APPS DTC and was that the only DTC it was throwing?
Also, check fuel pressure. I'm not saying you don't have a PCM issue however it does sound like the truck is starving for fuel
Old Jan 31, 2011 | 08:59 AM
Tkitt21's Avatar
It thre tps low voltage which is p0122 or p1022 or somthing like that and it threw p1693
Old Jan 31, 2011 | 09:05 AM
The p1693 is a "tag along" code. It is telling you that there are codes in your PCM
Sawyerorr
For Sale
Jul 22, 2015 12:45 AM
Jun 22, 2015 12:40 PM
hoeky22
For Sale
Mar 15, 2015 08:35 PM
Nov 24, 2014 08:20 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
