Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
FORD FRONT AXLES
Old Nov 24, 2007 | 08:57 PM
LOGANSTANFORTH's Avatar
Default FORD FRONT AXLES
1977-PREVIOUS F350, F250 snowfighter: low pinion dana 60, very weak.....
1978-1979 F350, F250 snowfighter: high pinion dana 60, kingpins, 35 spline outters, 30 spline inners, internally splined lockout hubs
1980-1985 F350/F250: high pinion TTB dana 50
1986-1991 F350: solid high pinion dana 60, king pins, 35 spline outers, 30 spline inners, internally splined lockout hubs, different spring spacing that 78/79 axle
1986-1989 F250: TTB dana 44HD/ TTB dana 50, both high pinion
1991-1997 F350: solid dana 50/solid dana 60, 50 hase smaller ring gear and axle shafts than 60
1990-1997 F250: TTB dana 50, high pinion
1999-2008 F250: solid dana 60, solid dana 50, both high pinion, metric pattern
1999-2008 F350: solid dana 60, high pinion, metric pattern
i think all those are right guys, i was just going from memory, been a while, i used to have a complete axle guide i wrote up for the internet but i somehow lost it...... i only added the axles worth mentioning putting under a diesel
Old Apr 9, 2008 | 11:57 AM
RTL Garage's Avatar
If I Am Not Mistaken - I Did Not Notice Any Difference From The 08' 250 Front Ends To The F350's.
Old Apr 18, 2009 | 10:42 PM
mr bad example's Avatar
where are you located HVAC guy?
I would really enjoy meeting some fellow IL SD owners!
Old Apr 25, 2009 | 06:28 PM
tundra smoke's Avatar
www2.dana.com/pdf/X510-2.pdf
Old Apr 30, 2009 | 11:46 PM
BLACK_06POWERSTROKE's Avatar
are you trying to sell these
Old May 2, 2009 | 03:19 PM
did you read the entire post.......most likely not or you would of seen this.....
Old May 2, 2009 | 05:11 PM
toy4xchris's Avatar
I think the super 60 pops up in the 450 and above which has a larger ring gear but a 10 lug wheel pattern but seems to be easy to convert back to 8 lug for those of you looking for something a little stronger.
nice post though Logan you always seem to be good for random info.
Old May 4, 2009 | 03:35 AM
you have the Super 60 and the Super 70 for front axles in the 450 and 550's just cant remember the years.....
Nov 4, 2014 01:30 PM
Oct 14, 2014 08:40 AM
