94-98 12V Cummins 5.9L P7100 Tech Talk '94-'98 5.9L Cummins 12-Valve P-9100 Tech Articles
Tork Tek Overflow Valve Install
Old Jan 21, 2011 | 06:03 PM
12vcummins96's Avatar
Default Tork Tek Overflow Valve Install
Tools needed
19mm and a 14mm open end box end wrench
time 30 mins
Here is the location of the OFV
Use the 14mm wrench and remove the plug that holds the spring in
Use the 19mm wrench and remove the OFV from inside the pump
Carefully lift the OFV and return line above the head dont pick up to high you can kink the line
Now remove the OFV
Here is the new Tork Tek 070hp Overflow valve
Make sure you replace the sealing washers
Push line back to the hole and start to tread the OFV back in by hand
Old Jan 21, 2011 | 06:06 PM
Now this is the job completed
This is my fuel pressure now after install
Hope this is informative
