loping idle
Old Jan 21, 2011 | 05:46 PM
riddick01's Avatar
Default loping idle
so the truck is an 03 7.3...custom tuned ts chip (murff racing)
tunes are as follows
1-hot
2-street performance
3-mild tow
4-lope
5-high igle (1200rpm)
6-no start
background info its about 40 or so outside truck has around 75k miles afe stage 2 intake 4" banks monster exhaust and some cosmetic stuff. injectors hpop icp and all that are stock to the best of my knowledge (bought it used so i cant say im 100% sure but id go 80-90% sure it is)
so the truck acts like its stuck in lope mode. it shakes like a **** at idle. i tried killing the truck then restarting it in a different position (i almost always start in street and did this time) and it still loped. i killed it disconnected the batteries let it sit for 5 or 10 min then started it again and got the same thing (not as bad a lope but still a lope)
if i take the truck for a decent drive (20 min at freeway speeds) then it wont lope till next time i start it up (even if i run inside a gas station to get a drink then 2 min later restart it).
as it stands when im driving i can switch between the 1st 3 tunes and feel the power difference (im assuming that means im not stuck in lope mode) so now im sitting here scratching my head wondering whats wrong.
any help with this would be awesome. im going to try to get a vid of it in a little bit
Old Jan 21, 2011 | 07:07 PM
Kyle_KleinSS's Avatar
What viscosity oil you running?
Old Jan 21, 2011 | 07:12 PM
riddick01's Avatar
rotella 15w40...no additives or anything fancy added into it
Old Jan 21, 2011 | 09:32 PM
CSIPSD's Avatar
Check your oil level, how old is the oil?
It sounds like an oil issue.
Old Jan 21, 2011 | 09:42 PM
I was thinking that too. Hey Joe btw can you check my thread, having and idle issue myself
Old Jan 21, 2011 | 11:23 PM
riddick01's Avatar
oils been in the truck since last monday (changed it after getting back from a hunting trip)...ill check it now and see how it looks and report back in a fre
checked the oil 4 times just to be sure and its showing it right at the top of the fill line so its full
http://s1093.photobucket.com/albums/i425/Jeremy_Stephenson/?action=view&current=MVI_0008.mp4thats a vid of it maybe 10 min after a few hrs of engine running (50ish miles there 50ish miles back from 65-75 and an hr or so of rolling around dirt roads at less than 20)
Old Jan 23, 2011 | 12:41 PM
riddick01's Avatar
well a little wrap up on this one...it finally threw a code (p1280) so i unplugged the icp sensor and it ran fine so im gunna run it with the wiring harness unplugged while i wait for the new sensor to get in
Daylon
Aug 23, 2015 11:01 AM
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
