Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Mystery Switch Instructions For 47RH trans.
Old Nov 24, 2007 | 12:19 AM
DB Admin's Avatar
Banned
Default Mystery Switch Instructions For 47RH trans.
These instructions for the mystery switch are for the 47RH not the 47RE.
The later transmission control has a relay that has to be removed and
the load pins jumped. The
'96 and later also have more than one orange with black tracer wires on
the PCM.
There are 2 (two) options you have between switches; a simple on/off toggle switch or a 3 (three) position toggle switch.
First off you will need to find PIN 54 and the wire attached to it (orange w/ black tracer). This pin/wire is located in the PCM connector located behind the air filter box on the passenger side of the firewall. Now heres were the 2 (two) options come in for the switch.
First is to use a simple on/off toggle switch and ground the wire w/o cutting it. This allows you to either manually lock the TCC or to let the PCM handle it.
Your second option for the switch is to use a single pole 3 (three) position toggle switch. To use this switch you cut the wire attached to PIN 54 of the PCM, attach the trans. end to the center pole, attach a ground wire to one of the outside poles, and attach the PCM end of the wire to the other outside pole. It is suggested to use different colored wires when you cut the wire going to PIN 54, so that when extending them into the cab you won't get them confused.
Old Nov 24, 2007 | 08:11 AM
DB Admin's Avatar
Banned
Does anyone have a Mystery Switch ?
Old Nov 24, 2007 | 12:19 PM
Crawler's Avatar
I do. Kind of. I don't have a PCM
Just a hard wired switch to my tranny.
But, I've done quite a few of them for customers.
~Wes~
Old Nov 25, 2007 | 12:52 PM
ndurbin's Avatar
Them instructions look kinda familiar.
I have the 3 pos. switch on mine. Comes in handy with the exhaust brake and towing. Otherwise I don't mess with it.
Old Jun 15, 2009 | 01:13 PM
davo79's Avatar
I put one in and the thing shifts my trans innto overdrive what the hell went wrong
Old Jun 18, 2009 | 07:45 AM
392hemix's Avatar
mine just locks the converter, i used pin 11 not 54 thoe, whent with the singl toggle switch
Old Jul 6, 2009 | 09:18 PM
tony lewis's Avatar
does anybody know how to wire this for a 47re
Old Oct 10, 2009 | 10:48 PM
mylilpwny's Avatar
what does this do exactly and wat gains or perks to it are there
cumminspwr11
12
Oct 17, 2021 03:50 AM
IslanderXJ
Dec 17, 2014 04:14 PM
