Dodge Diesel Tech Articles All Years of Cummins Tech Talk
5.9L Diesel Filter Water/Sediment Drain
Old Nov 23, 2007 | 11:54 PM
DB Admin's Avatar
Banned
Default 5.9L Diesel Filter Water/Sediment Drain
Drain the water and sediment from the separator each time the fuel tank is filled.
Shut off the engine. Manually open the drain valve until clear fuel is visible. Top Load Filter Type (1)
Pull up on the drain valve lever until fluid drains out of the drain tube. If nothing comes out of the drain tube, lift the lever several times to break the vacuum seal.
Spin-on Filter Type (2)
Lift up on the drain valve until fluid drains out of the drain tube. When finished, make sure that the valve closes.
NOTE: Some of the early 1st generation trucks have a screw valve without the WIF sensor. For these filters, you must unscrew the valve until the drain opens.
Attached Thumbnails 5.9L Diesel Filter Water/Sediment Drain-z.gif   5.9L Diesel Filter Water/Sediment Drain-zz.gif
Old Mar 27, 2008 | 05:23 PM
dieselsmoke74's Avatar
when i open my drain valved nothing comes out at all?
Old Mar 27, 2008 | 05:38 PM
xzaq103's Avatar
FormerVendor
Does your truck run? Whens the last time you changed the filter?
Old Mar 27, 2008 | 10:02 PM
yeah it runs i just bought it and i just changed it last sat! its an 2002 i read the manual and everything idk i cant figure it out maybe its clogged up somehow?
Old Mar 27, 2008 | 10:22 PM
xzaq103's Avatar
FormerVendor
I guess the tube could be clogged.
Old Mar 27, 2008 | 10:30 PM
so when i flip that valve to the left(drivers side)water should ruyn out and then clean fuel
Old Mar 27, 2008 | 11:35 PM
LOGANSTANFORTH's Avatar
i would rarely if ever get water, and when i did it was maybe a 1/4 of a teaspoon....
Old Mar 28, 2008 | 12:12 AM
xzaq103's Avatar
FormerVendor
Might try and take the canister off and shoot some air through it. As for water im sure some has been in there but i dont think its ever enough to notice.
Old Mar 28, 2008 | 08:25 PM
Sometimes you have to open and close the lever a bunch of times to break the vacume seal.
Old Apr 1, 2008 | 03:25 PM
Mr.Krabs's Avatar
I just do it when I change filters,I've never gotten much water,after I fixed that hole in my fill tube...
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
wolfnexus
Nov 4, 2014 10:04 PM
