94-98 12V Cummins 5.9L P7100 Tech Talk '94-'98 5.9L Cummins 12-Valve P-9100 Tech Articles
1994-98 Ram Diesel Fuel Shutdown Solenoid Adjustment
Old Nov 23, 2007 | 11:19 PM
DB Admin's Avatar
Banned
Default 1994-98 Ram Diesel Fuel Shutdown Solenoid Adjustment
To check the fuel solenoid adjustment:
1. Turn the key on but do not bump the starter
2. Get under hood and pull up the solenoid by hand (it will stay up when you let go).
3. Measure from the bottom of the solenoid mounting bracket to the top of the lever pin as shown in the diagram below.
4. The distance should measure 2.64 inches (slightly longer than 2-5/8" on standard tape).
5. If its not close, loosen the locknut on the solenoid shaft and turn the adjustment nut to get the correct distance.
Attached Thumbnails 1994-98 Ram Diesel Fuel Shutdown Solenoid Adjustment-1.jpg   1994-98 Ram Diesel Fuel Shutdown Solenoid Adjustment-2.jpg
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
wolfnexus
Nov 4, 2014 10:04 PM
