Dodge Diesel Tech Articles All Years of Cummins Tech Talk
home built cold air intake
Old Nov 28, 2009 | 04:11 PM
BC847's Avatar
Default home built cold air intake
Now remove the passenger's headlights and such so that you can grind away any high spots so the pot's feed duct will sit flush to the back of the radiator support.
Cut a bunch of holes around where the headlights / turn signal goes.
Make it all so that when it's put together,
100% cold air is drawn through to the BHAF.
You may have to move the radiator's reservoir over a little to have things fit. The stock/OEM turbo intake duct will work just fine if you're in a pinch.
Works good for me.
If you're in a hurry, simply replacing the stock/OEM air filter box's intake feed-horn/muffler with a bigger duct works wonders.
shawnecarter
6.0L Performance
Mar 17, 2015 05:49 AM
hoeky22
Jan 2, 2015 04:54 PM
Project_5.9diesel
Dec 11, 2014 09:41 PM
12vbomber
Nov 4, 2014 10:04 PM
petew
Oct 25, 2014 09:29 PM
