Getrag Help!
Old Jan 10, 2011 | 06:15 PM
hagerty_justin's Avatar
Default Getrag Help!
hey, i have found a decent deal on a getrag360. I bought a 91 d250 to do a swap into my 75 f250 4x4, as some of you know the 75 fords had a divorced transfer case. The getrag 360 is a 4x4 transmission I just need to know if the only part i need to change is the tail piece to make this tranny 2wd? or do i need to change any output shaft or anything else?
Thanks
Old Jan 12, 2011 | 04:02 AM
cumminsblazer's Avatar
Lol u wanna trade trannys I got a 2wd????
Btw u would need to change the tail shaft and the tail housing btw do u have the transfercase ???
Last edited by cumminsblazer; Jan 12, 2011 at 04:02 AM. Reason: Automerged Doublepost
Old Jan 12, 2011 | 09:54 AM
i have no bought the tranny yet, but that is possible. Although im all the way up here in seattle
but i do have a 4x4 727 with a mated np 205... if you want an automatic
Last edited by hagerty_justin; Jan 12, 2011 at 09:54 AM. Reason: Automerged Doublepost
Old Jan 12, 2011 | 11:39 PM
I just got done making my divorce t-case fit in my blazer what a pain in the *^• but thanks but that's a little far away for me
Old Jan 13, 2011 | 12:01 AM
big bad diesel 416's Avatar
Site Sponsor
Thanks
You have to pull the main and input shafts and strip the main of all the gears and bearings and put in a 2WD main shaft then the 2WD tail shaft I have a main shaft if you want to go that route and a rebuild kit is not a bad idea since your that far in there
Old Jan 15, 2011 | 02:45 AM
Well, it looks like I need to find a 2wd tranny then, I hope a zf5 from a 7.3l
Old Jan 15, 2011 | 11:33 PM
FastCR's Avatar
if you want to stick with divorced, get a 2wd trans. Those little things add up. If your deep enough into it, you should consider just getting an nv4500. They aren't terribly expensive if you shop around, last one i got for $500.
Old Jan 16, 2011 | 12:02 AM
Ya, if I could find one for 500 I would buy that. I have not seen many up in the Seattle area. The only transmission I have seen latley was a 4x4 getrag, and im not sure I want to do all that work to change it over to a 2wd. What is different about a chevy nv4500? I have heard that they are build weaker then the dodge ones, what about bellhousings bolting up the same? I.e would a cummins bellhousing bolt to a chev nv4500?
Old Jan 16, 2011 | 12:14 AM
FastCR's Avatar
bellhousings will interchange. input shafts between cummins and late chevy 4500 without the granny 1st will interchange with their respective retainer.
the chevy shaft is thinner but has a harmonic dampner.
Old Jan 18, 2011 | 04:31 PM
hey Big Bad Diesel, how much would that shaft run? or would you do a trade my old 4x4 shaft for your 2wd shaft? and what about a tail shaft?
