hemi to cummins
Old Jan 9, 2011 | 11:37 AM
twistedtat's Avatar
Default hemi to cummins
anybody know how hard it would be to
swap an 05 2500 hemi with a cummins?
Old Jan 9, 2011 | 12:30 PM
Horns's Avatar
One of the easiest swaps to do since every part Is factory made.
Old Jan 9, 2011 | 12:40 PM
Red_Rattler's Avatar
High Tech Redneck
Complete motor including harnesses and all computers, new tranny, tcase, driveshafts, rear end, gauge cluster, hydro boost brake master cylinder setup, fuel lines, fuel basket will have to be swicted out in the tank along with fuel pump and a couple other odds and ends... Wont be emission comliant since its a gas vin with a diesel in it... Sell it and buy one
Old Jan 9, 2011 | 02:14 PM
haulitrite's Avatar
I have both a Hemi and a cummins and just looking under the hoods of each there I would have to think everything would need to be changed out due to the size of the cummins.
Battery location, air to air, radiator, battery locations, and I'm not sure but it seems like the fire wall is stamped different for the cummins. NOT SURE THOUGH.
The pictures may show the difference but the size comparison is night and day. You can fit 2 hemis under the hood and the cummins is wrapped pretty tight.
Attached Thumbnails hemi to cummins-hemi-cummins-001.jpg   hemi to cummins-hemi-cummins-002.jpg   hemi to cummins-hemi-cummins-003.jpg   hemi to cummins-hemi-cummins-004.jpg
Old Jan 16, 2011 | 12:51 PM
twistedtat's Avatar
sounds tough think ill just trade it
thanks
Old Jan 28, 2011 | 12:33 AM
Hobbychoppers's Avatar
Getting the motor in isn't the big deal, The wiring is the big deal. I've done this swap on a 2000 ram, the motor was in in a weekend, but it took myself and a dodge tech to figure out all the wiring schematics about a month and a half. The swap in total cost me about $6000. Now that all the bugs are worked out it's a great truck, but do your homework and be prepared to tough it out. Good luck
Old Jan 28, 2011 | 07:07 PM
twistedtat's Avatar
thanks for the info,i guess what i want to know is , will everything fit and bolt up.
what about trannys, will they interchange or no ? what about a 12v in a 05?
might be crazy!@#$%
Old Jan 29, 2011 | 04:35 AM
I can't truthfuly answer that, the 12v came in a different body style and I'm not sure if there's a difference in the mounts from 12v to the 24v or CR. I don't know where you live but you're stepping into emission problems going that far back to a 12v. Technically (and someone correct me if i'm wrong) I think you can transplant the same year or newer and still be politicaly correct. I don't have any room to preach here because I put a 95' 12-v in a 2000, but I know who inspects my truck, plus we don't have emissions at this time. But hey, like I said do some research and this is the right place to get info. Good Luck
I can't honestly answer that, I'm not sure if the mounts are the same from the 12v to the 24v or CR.As far as trans. goes if you have the nv 5600 already (and I don't know what you have) this will work but you will have to change the input shaft,which depending on how many miles you have could be a 20 minute job, or you may need to ad shims behind it to eliminate end play. I don't think the auto will work,I'm not 100% sure but I've read discussions that if it's behind the v-10 then it will but i'm not sure exactly what has to be modified.
Last edited by Hobbychoppers; Jan 29, 2011 at 04:35 AM. Reason: Automerged Doublepost
Old Feb 21, 2017 | 09:37 PM
Jackson Jones's Avatar
Default 5.7 hemi to 5.0 cummins
I'm just spitballing here but I have a 2013 dodge 1500 4x4 with the 5.7 hemi, could I possible swap it with a 5.0 cummins like what's in the new Titans? I'd imagine the transmission will have to be swapped but I'm wondering how tough of a fit it would actually be?
Shun70
Sep 21, 2015 01:39 AM
Sbboozer
Nov 16, 2014 05:52 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
