mercedes/toyota conv.
Old Dec 31, 2010 | 12:33 PM
pukie370's Avatar
Default mercedes/toyota conv.
I have heard of puting 4 cylinder mercedes in toyota truck, has anybody done. i think it would make a great combination since i have my old trusted toyota but it has wore out motor. If anybody knows where to get adapters please let me know.
Old Jan 1, 2011 | 12:14 AM
superduty_5.9's Avatar
Others have done this. Do a Google search. There is a few on other forums. Not to be a dick or anything but German engineering is way better than the Asian engineering. Asian especially Toyotas rust on the new car lot. I personally would find at least something American to put this fine powerplant in. Not trying to bust your ***** but I've seen way to many Toyotas go to the scrap yard for that reason.
Old Jan 1, 2011 | 06:22 PM
seaglf's Avatar
Default stick with toyota
why not just put what should go in there, a KZ 3.0 liter 4 cyl. toyota diesel, or a newer KD 3.0 liter diesel.
At least there's a better chance that it will mate up to your tranny. And if you are thinking of putting a 4 cyl. mercedes,like the OM615,616,etc. they have less power then the toyota 4cyl's I mentioned.
Most people doing any mercedes swaps are using the 5 cyl. OM617 3.0 liter because they can be found anywhere cheap, and have similar power ratings to the 1KZ-t
Old Jan 2, 2011 | 11:46 AM
pukie370's Avatar
some people dont like toyotas but i live in the hills and old toys are the only truch that holds up to the bad roads, i just talket to a guy that will make adaptor and redrill flywheel to mate the 4 cylinder mercedes motor to the toy trany, i think cool, i was told that these combos get 30 mpg and have great torque
Old Jan 3, 2011 | 11:23 AM
seaglf's Avatar
I don't know what 4 cyl mercedes you are referring to, but if you already have it you might as well use it. I assume its the OM616.
The OM616.916 was a 2.4 L (2404 cc) engine with power output of 65 hp (48 kW). In August 1978 the precombustion chamber was updated for more swirl and more efficient combustion. The engine capacity was lowered to (2399 cc) to satisfy engine displacement tax laws in europe, but power output rose to 72 hp (54 kW).
since they are probably the most common 4 cyl Mercedes available here. Anyway they don't have much power, but would probably be cheap and easy to increase the power.
Old Jan 3, 2011 | 02:58 PM
pukie370's Avatar
im not using truck on highway, it spends most of the time off road and i value not dumping lots of gas in to keep runing. i think the 616 ig very affordable power plant.
Old Jan 4, 2011 | 04:42 AM
rab475's Avatar
I have a 616 in my wrangler. You will lose some hp but tq will be about the same as what you have now. If your swapping for milage your wasting your time if you just want a diesel its a good engine my 240d has 490k on it but you will never get honest 30mpg.
Old Jan 4, 2011 | 07:38 AM
jmac5058's Avatar
Have you looked at the 2.7 (I think) I-5 they put into sprinter vans before changing to a V-6?The auto trans is a 5 speed and are quite stout.
Old Jan 4, 2011 | 10:56 AM
Those would be great but would be a wiring nightmare! I wonder how much power the ones in the sprinters put out?
Old Jan 4, 2011 | 12:40 PM
seaglf's Avatar
OM647 DE LA 27
Cylinders 5
Arrangement in-line
Capacity 2686cc
Bore 88.0mm
Stroke 88.4mm
Compression 18.0:1
Valves 4 per cylinder
Camshaft(s) 2
Firing Order 1-2-4-5-3
Head alloy
Block cast iron
Delivery Bosch CDI
Induction Turbo Charger
VTG-loaders
Horsepower 154hp
@3800rpm
Torque 243ft-lbs
@1600-2400rpm
115kW CDI
The OM647 is a 2.7 liter, five-cylinder "C"ommon Rail "D"iesel "I"njection (CDI), inline, and overhead valve diesel engine. This engine utilizes a cast iron cylinder block and an aluminum cylinder head. The engine is turbocharged and intercooled. This engine also has four valves per cylinder and dual overhead camshafts.
A very distinguishable aspect of the OM647 from the very similar OM612 predecessor is its intake manifold.
That would be a great engine for many swaps, except for what he wants, I think they would be costly, and then there is all the wiring. I would like the OM642 because they have a Aluminum block and only weigh 460 lbs, and come with a 7 speed tranny.
Anyway I have already been considering a Toyota swap. Either a 4 runner,or a Tacoma, and even a Rav 4. But if and when I do, I will put toyota diesels in them. Todd with Dieseltoyz in San Antonio Texas does toyota swaps for a living.
