6bt squeak? (not the belt)
Old Dec 24, 2010 | 06:56 PM
hagerty_justin's Avatar
Default 6bt squeak? (not the belt)
hey I just bought this engine to do a swap into my 75 f-250 4x4, the engine had 149k on it when the guy rolled the truck. I fired the engine up and a squeak comming from the left hand side of the block, right by the mechanical transfer pump. I hope its not a bearing but take a listen and let me know what you think?
watch the video below
Old Dec 24, 2010 | 07:05 PM
blazier18's Avatar
im not sure wat it could be. but if u take a piece of hose to use it like a hearing aid kinda or one of them nurse things they check ur heart with that could help and u could also use a water hose and where the noise is when u hit it witth water it should quit for a second or two
Old Dec 24, 2010 | 07:10 PM
ya the squeak sounds internal right by the mechanical transfer pump
Old Dec 24, 2010 | 07:14 PM
blazier18's Avatar
im not that familiar with the mechanical transfer pump but a water pump can squeek like that have u checked all ur fluids
Old Dec 24, 2010 | 07:18 PM
ya good oil, thats the only one that counts . the radiator isn't even on the frame so maybe it is the water pump? i hope so ill put the hose to it and see if it still squeaks
Old Dec 24, 2010 | 07:25 PM
blazier18's Avatar
they sqeek bad i really could help u better if i was there i guess thats most cases though
Old Dec 24, 2010 | 07:32 PM
ya that would probably be the best way. ill get some of my dads friends to take a listen to it.
Old Dec 24, 2010 | 07:42 PM
blazier18's Avatar
just get the radiator and hose hook it up and see it if it stops even if it dont it could still be a bad water pump
Old Dec 24, 2010 | 08:34 PM
okay, it sorta sounds like rings to me? or bearings. guy said it sat for 9 months some people have mentioned that filling the entire engine with oil to preserve it will help when storing? would this help just to get everything lubed up? i only ran it for less than 2 minutes total
Old Dec 24, 2010 | 09:00 PM
blazier18's Avatar
rings? bearings in ur motor as far as rod bearings and main bearings would knock and eventually throw a rod thats how it was in my sbc's my truck has set for a few months at times and started rite up if the motor was locked up then id put oil in it where ur injectors go in
