transfer case question
Old Dec 24, 2010 | 12:52 AM
justgmtrucks's Avatar
Default transfer case question
hey guys i need help with my project, I have a 82 chevy 1ton 4x4 crew cad truck that i am swapping a cummins engine. I got a 1998 dodge 3500 4x4 rollover. My question is that i dont want to change my front axle in my truck is there a way to mate the dodge automatic
trany to my 205 transfer case or use a diffent tranfer case.
Old Dec 24, 2010 | 01:28 AM
cummin_un_glued's Avatar
FormerVendor
yes you can mate the dodge auto to your 205...just takes a 23 spline input shaft and sleeve for the 205....i have one, but they are really hard to find...i was going to do something similar but now i'm putting my 205 behind a dodge 5 speed
Old Dec 24, 2010 | 02:27 PM
thank for the info, what year or kind of truck can i find the shaft and how hard is it to do it
Old Dec 25, 2010 | 01:27 AM
cumminsblazer's Avatar
The np 205 is pretty easy to work on but u need to look for one behind a cummins 89-93 the adapters should be the same too both the th400 and cummins have the same 6 bolt np205 mounting
Old Dec 25, 2010 | 02:20 PM
HRDROKN's Avatar
If you can find the 89-93 Dodge Cummins 23 spline (auto truck) NP205... its a bolt on!
The GM NP205 uses something like a 10, 27 or 32 spline input and I have not seen any adapters suitable for the Cummins torque. I even had to scrap a 29 spline to 31 spline Ford conversion due to the spud coupler being a huge week link.
Old Dec 26, 2010 | 06:15 PM
crewcab59's Avatar
The auto will give you some trouble also if its a 47RE it wont know when to shift, but the 47RH will run with out the ecm, and use toggles for o/d and lockup. im sure there is a way around it though, good luck on your swap.
dezeldoc
Wanted To Buy (WTB) - Used
Jan 27, 2016 05:08 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
miked2805
Oct 19, 2014 11:02 PM
steves2500diesel
Oct 14, 2014 05:36 PM
