Chevy/GMC Duramax 07.5 -10 LMM Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines
Questions on Batterys going dead, I-Arm, Tranny cooling lines
Old Dec 13, 2010 | 09:31 PM
Dirtymax13's Avatar
Default Questions on Batterys going dead, I-Arm, Tranny cooling lines
First problem is batterys, If my truck sits for any lenth of time it either starts hard or is dead if i run my radio without running 20 mins max dead alternator good batterys test good, Second I-Arm for steering rattels when turning i have seen other post about this where would i buy a new aftermaket one ,cause i heard factory will do the same thing again, Third my tranny cooling lines have been replaced once already and a diferent one is leaking now 50,000 wtf
Old Dec 14, 2010 | 01:37 PM
BriteWhiteRam's Avatar
cooler lines are garbage, get some new ones made up or buy a kit like i did
chevy silverado duramax transmission cooler hoses on eBay.ca (item 180599590768 end time 21-Dec-10 10:59:12 EST)
Old Dec 14, 2010 | 02:37 PM
2500HeavyDuty's Avatar
your going to have to pull the amp meter out and test for any unwanted battery drain with the truck off.
do you have any aftermarket electronics installed?
Old Dec 22, 2010 | 02:20 PM
BLACKDX's Avatar
Just do what BWR said or take your lines of and go to a hose shop on get some real ends and hose made up.. They will never stop leaking especially if your in a colder climate..As for the Batt ya must have a drain on it some where, I know mine won't handle much as well but its only sometimes. I think if something is left on plugged in it must activate the BCM or something cuz mine has did this as well..the only thing i had plugged in was a phone plug. I know with my PPE sometimes I could never load a tune it would lock up, had to unplug several times and reastart the truck ans so on. Was told by PPE that if the BCM stays powered up that that would cause issues with the programming.. Dunno
Old Dec 22, 2010 | 10:41 PM
Dirtymax13's Avatar
Thanks for your help
