Duramax 2" Lift
Old Nov 16, 2010 | 11:58 PM
LB7DuramaxMeggers's Avatar
Default Duramax 2" Lift
im looking to put bigger tires & wheels on my 01 duramax, i know to put bigger tires i will need some sort of lift. as of right now ill prolly just do 2" blocks in the rear then either crank up my stock torsion bars or buy new bigger torsion keys. i just dont want my truck to ride like complete d***. i was just wondering about personal opinions and what is the easiest way to get the job done.
Also would it be better to buy the shock extensions or just buy new ones? their older shocks and im sure they could be replaced.
thanks.
Old Nov 17, 2010 | 10:25 AM
1AMatt's Avatar
Site Sponsor - 1aauto
What size tires do you plan on running?
Old Nov 17, 2010 | 11:02 AM
Shocker's Avatar
For the BEST RIDE... once you crank the "torsion bars" you should purchase Cognito Upper Control Arms, Shock Extensions/Longer Shocks, Cognito Pitman & Idler Support Kit.
When you crank your torsion bars your suspension travel "Droop / Down Travel" is almost gone. Installing the UCA & Shocks/Shock Extensions help gain back what you've lost. There have been many people out there making the Low Buck choice which ends up in costly repair down the road.
We have installed many of these on the 01-10 2500HDs with great success and satisfied customers. If you have any questions or would like us to help, let us know.
Old Nov 22, 2010 | 01:10 AM
im going to buy 2" blocks and a set of bigger torsion keys. ive heard of people running 315s with just this set up?
I know the best way to do it is to buy a full suspension lift but thats not in the price range at the moment. i know "good **** aint cheap and cheap **** aint good." I just cant afford that. so im curious to see what i can run with just the 2" lift and torsion keys.
Im gonna buy new longer shocks. Any recomendations?
Last edited by LB7DuramaxMeggers; Nov 22, 2010 at 01:10 AM. Reason: Automerged Doublepost
Old Nov 23, 2010 | 03:18 PM
Nor-Cal Nick's Avatar
315's will wear your front end with a leveling kit, it has been done but expect to pay for the wear items and handling to be the reflecting issue's. How about not going to such a large tire and get a happy middle. If you plan it right you can purchase as you go and end up where and what you want to be on. Let me know if you need help planning it out, we now off FREE Suspension Consulting if you would like to go over options personaly over the phone.
landon025
Sep 8, 2015 09:21 PM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
