Oil pump replacement
Old Nov 11, 2010 | 05:40 PM
waggthis's Avatar
Default Oil pump replacement
hi guys,
i need to change the oil pump in my work's 1999 delivery truck with a 5.9 in it, and i can't find any info online on how to do this, and if there is anything i need to look for as far as the fuel pump, timing, and such.
can anyone here give me a crash course on how to do this?
Old Nov 11, 2010 | 07:54 PM
Whit's Avatar
Site Mascot
how did you determine it needs a new oil pump????
bad pressure sensor giving you low numbers?
The oil pump will outlast the motor even at a million miles
Old Nov 11, 2010 | 11:11 PM
waggthis's Avatar
we changed the oil pan gasket and found like 20 little pieces of cast iron and a washer broken in 4 pieces and one of the cast iron pieces is a number 8. we took it to Cummings and they said it looks like pieces of oil pump and the motor has like 5-10 lb
a tech says the washer looks like a piece of the bypass valve from the oil pump
HeavyChevy95
Dec 21, 2016 10:36 PM
b&hbiz
Sep 9, 2015 07:53 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
Bighouse
Apr 9, 2015 06:51 PM
moneypitk5
Feb 12, 2015 11:01 AM
