Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
cleaning the dual tanks
Old Nov 7, 2010 | 06:27 PM
ESS's Avatar
ESS
Default cleaning the dual tanks
So one of my projects for the upcoming year is to add a WVO system to the 8.3 Cummins FL70. The problem I posted about in the big rig section (plug where filter should be) has been corrected, I replaced plug with fuel/water seperator. I can only imagine that the filter kept getting plugged from debris in the tank, the previous owner got tired of replacing plugged filters so just did away with the filter. So now I need to clean the tanks, something I have never done. Any tips?
FYI- since the FL has two tanks, I am thinking of setting one up for the bio warm-up, and the other tank for the WVO. Anyone done this or see a problem with the idea?
Thanks!
Old Nov 7, 2010 | 07:13 PM
tiremann9669's Avatar
Sounds like a good Idea
Old Nov 10, 2010 | 01:36 PM
ESS's Avatar
ESS
Anyone here running WVO in an 8.3???
Old Dec 9, 2010 | 10:10 PM
Screamin' Metal's Avatar
cool
I know alot of folks that do. Cummins has a setup that takes some oil out of the crankcase and adds it to the fuel system. Cummins says its motors are made to run up to 10% WMO....
Old Dec 10, 2010 | 08:18 AM
ESS's Avatar
ESS
Didn't know that. Do you have any idea the best way to clean out a tank? I figure wet vac the inside but then what? I have Kreemed the inside of motorcycle tanks, anything like that for diesel?
Old Dec 10, 2010 | 08:25 AM
moneyman_09's Avatar
Are the tanks rusty or do they just have sediment in them?
Old Dec 11, 2010 | 11:46 AM
ESS's Avatar
ESS
I have no idea. There is fuel in them so I can't tell what type of debris it is.
Old Jan 1, 2011 | 05:21 PM
superduty_5.9's Avatar
I would remove as much fuel as possible then get a brush sort of like a gun cleaning brush but bigger with a long flexible shaft. Then an air hose with a long wand. This is just for sediment. If it is rust too which I doubt then I still do the same thing but try to coat the inside with epoxy paint for fuel tanks.
Old Jan 13, 2011 | 07:29 AM
ESS's Avatar
ESS
Thanks Superduty 5.9. I didn't know there was a paint that would withstand fuel. I'll look into it.
Old Jan 13, 2011 | 11:53 AM
Deezel Stink3r's Avatar
If you want to run WVO don't do anything than just replacing filters.
Run VO first. VO has extremly good cleaning abilities. So if your filter pluggs up- this is caused by the cleaning power of VO.
Change the filters and have spares at hand.
hollywoodbusa
For Sale
Feb 22, 2015 08:03 PM
Slim Whitey
Nov 8, 2014 09:41 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
Dual Liner
Shade Tree , Pro-Mechanics & Fabrication
Jul 2, 2012 08:36 AM
