HELP! power steering and brakes gone!
Old Nov 3, 2010 | 10:41 PM
redrocket9793's Avatar
Default HELP! power steering and brakes gone!
On Monday my power steering and breaks went out all of a sudden after letting it run and figuring out the suply from the power steering pump is not flowing at all so we replaced it that day. First start it was back to normal then it made an annoying fluttering noise when we checked the fluid level it was empty so we added more and thought it was air in the system and today it was on jackstands and seemed to work on the test drive I lost all steering. And most of my brakes any advice?????? Any and all help I need this truck every day
Old Nov 3, 2010 | 11:20 PM
94cummins diesel's Avatar
hydro boost is junk that happened to me yesterday
Old Nov 4, 2010 | 08:43 PM
Sad
Do you know why my power steering doesn't pump cus when we replaced it and cracked the like it was insane pressure but now has none and that's the line that feeds the hydro
Shaft sheared got another new one today and now isn't pumping for some reason
Last edited by redrocket9793; Nov 4, 2010 at 08:43 PM. Reason: Automerged Doublepost
Old Nov 5, 2010 | 03:58 PM
tiremann9669's Avatar
I'm not familiar with the hydro setup, is your pump mounted on your vacum pump ? possibly a problem with the gear or shaft on the vacum pump if it is.
Old Nov 7, 2010 | 04:22 PM
It was a combo of my steering box, hydro, and power steering pump fixed now thanks guys
ramrunner01
Jun 1, 2015 12:10 AM
01cummins4ever
Mar 20, 2015 09:25 AM
scottxmorris
Nov 30, 2014 09:25 PM
GCTownes
Oct 21, 2014 10:17 PM
1MooseheadPlease
Oct 13, 2014 05:33 AM
