service 4 wheel drive light
Old Oct 29, 2010 | 07:49 PM
GmCjOe's Avatar
Default service 4 wheel drive light
My 02 gmc 2500 has a service 4wd light that keeps comming on about every 30 miles a when im in 4 wheel drive and it comes on it won't go into 2wd until i shut the truck off and the light goes out any ideas what the problem is thanks
Old Oct 30, 2010 | 05:48 PM
dmaxtothemax's Avatar
My service 4wd light came on yesterday and has not gone off... the selection lights and controls on my dash quit working... i checked the fuse and the fluid level and both are fine... Anybody with any suggestions???
Old Nov 15, 2010 | 01:40 AM
GmCjOe's Avatar
I narrowed mine down to the switch or t-case but i haven't been home to see what it is yet but when i do i will let u know. If uu get urs fixed let me know what ur problem was thanks man
Old Nov 15, 2010 | 04:16 PM
Yeah, that's about where i'm at... I will let you know of any progress
Old Nov 16, 2010 | 08:07 PM
see if this helps you out any / worth a try...
http://www.automotiveforums.com/vbulletin/t125302.html
Old Nov 20, 2010 | 01:10 AM
GmCjOe's Avatar
Thanks bro im gonna try it i hope its just the switch but i will be home this week i will let u know something
Old Dec 3, 2010 | 02:09 AM
whiteboyinaz's Avatar
Also might want to check the ground wire from the tranny/tcase wire harness. It should run from that harness to the frame just under the driver door. The bolt could be stripped of not getting a good ground. Easy check and fix i hope for both of you.
Old Jul 20, 2011 | 07:23 PM
GMCJOE, did you ever figure this thing out???
I changed the 4wd transfer case motor on mine and she's works like new again...
Old Jul 27, 2011 | 12:06 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Most of the time i see this light is because the dash switch has gone bad... Thats why I like our plow truck, manual shift transfer case
Old Aug 3, 2011 | 10:17 AM
CoreyDyoung's Avatar
See and my experience has been complete opposite of yours I had a 2000 chevy 1500 and I replaced the switch and then after that went and got a junkyard motor with 60k miles on it and never had the issue again and then I changed a 06 avalanche's transfercase motor and solved the issue for that one to. I feel more commonly its the transfercase motor.
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
6.5dieselman
Feb 26, 2015 04:45 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
yams
Dec 7, 2014 12:51 PM
2002cabandchassis
Oct 29, 2014 01:59 PM
