6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
94 6.5 stalling
Old Oct 27, 2010 | 12:54 AM
thisguy5674's Avatar
Default 94 6.5 stalling
i have a 1994 gmc sierra 6.5 turbo diesel and i replaced the fuel filter and bled the filter a few times now but for some reason the engine sputter occasionally and if the truck has been off for 30min to 1hr 30min its stalls about 10 seconds after started. what can i do to fix this problem?
Old Oct 27, 2010 | 08:26 PM
Crazy's Avatar
Do a LP and OPS test,Put clear hose on the return line on the IP to see if you sucking air
Also recheck the fuel filter to make sure it seated right
Old Oct 28, 2010 | 11:55 AM
Walking J's Avatar
I'm going to go with a guess. You have a pinhole sized leak between the IP and the fuel manager. The hose has been in an unbelievably hot area for 16 years and is likely rotting and slowly allowing some air in. The fuel manager has a line into it from the back that can also become brittle and weak/leaky.
You could also have a weak lift pump.
Old Nov 15, 2010 | 06:06 PM
1994 GMC 6.5's Avatar
think it might be the injector pump,i had the same problem
Old Nov 16, 2010 | 09:36 AM
74truckin's Avatar
I have a 99 gm diesel and mine is doin the same thing. i put it on a copmputer and it said the cam position sensor is junk. The problem is I was told the cam sensor is built in the injection pump so now I have to replace the whole pump. $1,000 down the tubes!!!
Old Nov 16, 2010 | 10:02 AM
Crazy's Avatar
what code was you getting for bad cam sensor
Old Nov 16, 2010 | 07:51 PM
Ive been doing alot of research 0n the 94 6.5, the pmd causes alot of stalling problems,the best thing to do is relocate the pmd away from the engine so it wont over heat, dealerships will tell you need a injector pump,somtimes its just the pmd it take bout 20 min to do ,heath diesel have the best product with 7 year warranty
Read more: https://www.dieselbombers.com/6-2l-6...#ixzz15V4y0giW
Last edited by 1994 GMC 6.5; Nov 16, 2010 at 07:51 PM. Reason: Automerged Doublepost
Old Jan 13, 2011 | 07:19 PM
no codes
Old Jan 17, 2011 | 10:17 AM
Default Relocated pmd
i relocated my pmd ,been driving it a month with no problems pmdcable.com
rusty 6.5
Jun 13, 2015 05:45 PM
Levis95
Jan 11, 2015 01:54 AM
Noshawn
Dec 24, 2014 09:30 PM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
