Help ASAP
Old Oct 25, 2010 | 02:21 PM
2000stroker's Avatar
Default Help ASAP
i have a 2000 7.3L stock and have to have it smog (thnx California ) and i have codes p1391 p1393. would it be more likely that the glow plug relay is out, and if so how could i test it real quick to find out?? thanks...
Old Oct 25, 2010 | 02:34 PM
theSLEEPER's Avatar
Clear the codes, then test to see if they come back. But yes, most likely, the GP relay is to blame. To test it, I'd get a voltometer, and test to see if you're getting voltage across the big lugs when the key is turned on.
Old Oct 25, 2010 | 02:46 PM
Default got voltage
i checked the voltage on my glow plug relay and i had 12.6. any idea on what i should do next would help out alot....
Old Oct 25, 2010 | 03:34 PM
theSLEEPER's Avatar
Did you have it on both sides?? Just checking, but with the key off, one lug should be hot, and the other not. Then when the key comes on, both should be hot.
Old Oct 25, 2010 | 06:36 PM
Default Glow plug relay
i checked it and one lug was hot with the key off but when i turned the key on there was still only one lug that was hot. Would that mean its probably the relay? is there any way to test just the relay to be sure??
Old Oct 26, 2010 | 09:26 AM
theSLEEPER's Avatar
That is the way you test the relay... If there's no power going to the big lug, then there's no glow plugs...
GT_Eleanor
Aug 25, 2015 09:35 AM
willis964x4
9
Aug 22, 2015 12:21 PM
jeremiah1
Jun 21, 2015 06:45 AM
canigeta727
Mar 18, 2015 05:00 PM
yfzrunner
Feb 7, 2015 10:52 PM
