oil pressure
Old Oct 20, 2010 | 11:27 PM
Lange503's Avatar
Default oil pressure
at idle the oil pressure gauge will drop, but once i tap the throttle it will go back to normal.... wtf? i'm hoping its just a stupid sending unit
Old Oct 22, 2010 | 10:35 AM
Lange503's Avatar
bump?
just replaced the sending unit on top of the HPO res. and still nothin, what other sending units are there, anyone know?
Old Oct 22, 2010 | 11:44 PM
Jeff Davis's Avatar
I looked in the (haynes) manuel to see if i could find any other sensor and it just lists the oil temp which is located on the side but does not indicate that it has any association with the oil presure gauge, but it sends signals to the pcm for proper functioning of the fuel injector, did say to remove the pressure sensor and hook up a pressure gauge and fitting to the resivior and start the motor and read the pressure from that to isolate wether it is oil problem or gauge problems. let you know if I find anything else
Old Oct 23, 2010 | 12:01 AM
Lange503's Avatar
i didn't even think of hooking up a gauge to that, i'll see if i can't find one tomorrow morning, thanks
Old Oct 23, 2010 | 12:27 AM
Jeff Davis's Avatar
the book also said that the resivior runs under the same amount of pressure that the engine runs, at idle is10 psi, and at 3300 rpm 40-70 psi, never took my truck that high of rpm maybe that why I think that mine is messed up possibly that I am not driving it right I never go over 2000 what do you think.
Old Oct 25, 2010 | 03:19 PM
Lange503's Avatar
you must get good fuel mileage, but only time mine ever gets close to that is when its a WOT, but saturday afternoon my engine temp gauge spiked so i shut the truck off and popped the hood and then i watched all my anti-freeze drain into the motor
Old Oct 25, 2010 | 06:04 PM
jshblain's Avatar
how often do you do oil changes?
Old Oct 25, 2010 | 07:16 PM
Jeff Davis's Avatar
My 2000 7.3 tack shows that it 3300 is at red line I noticed that on saturday also approx. 45 minutes before I pulled off the freeway and what I think is the IDM killed my truck and left it stranded. I coach 6,7,8 yr old football and I was on my way to the playoffs with two of the players in the back. lost the game truck died shitty day. and yes I get great gas mileage 60miles and not a drop of fuel used ,but the suburban that towed me got 5 mpg that day.
Old Oct 26, 2010 | 11:00 AM
Lange503's Avatar
every 3k sounds like both of us had a shitty day ha, also check the CPS too that can just kill your truck out of no where when it goes it
Old Oct 26, 2010 | 06:57 PM
CSIPSD's Avatar
Oil pressure sender on our trucks is more of an on-off switch... It does not really read pressure. If you replaced the sender, I would check some of the wires for broken wires or chaiffed wires. If not, put a manual gauge in there and check again.
