2000 cummins, rattle
Old Oct 16, 2010 | 03:23 PM
James_M's Avatar
Default 2000 cummins, rattle
OK, I have a 5spd in my truck, and when I let the clutch out after shifting up, 80% of the time there is a rattle noise. This noise also happens if I let off the gas at lower RPM's and coast for a little bit. Any ideas?
Old Oct 16, 2010 | 04:23 PM
crzycummins's Avatar
u joints?
Old Oct 16, 2010 | 04:25 PM
James_M's Avatar
I got under the truck and checked everything out and they all seemed fine, it sounds like something is wrapped around the driveline, but I cant find anything.
Update: The noise is coming from under the truck, not engine compartment, I have got that far. Like I said before, while taking off, there is a small click sound, then it sounds like something is wrapping around the axle, then when I get up to speed it goes away. When I left off and get into the lower RPM's, there is a rattle noise for a couple seconds, sounds like metal on metal, then it goes away. I have searched my truck bumper to bumper under neath and can not find the issue.
Old Oct 19, 2010 | 02:33 PM
James_M's Avatar
Can anyone recommend a shop in Houston area to get my truck checked out?
Old Oct 19, 2010 | 05:59 PM
Farmboy 2.0's Avatar
Id check u joints, shocks, sway bar links, ect
Old Oct 19, 2010 | 08:04 PM
DuramaxDiesel02's Avatar
Default Re: 2000 cummins, rattle
Put your truck on Jack stands and have a friend walk under/around truck while driving to listen for it?
Sent from my Rooted Droid as I'm driving 70MPH down the road
Old Oct 19, 2010 | 08:08 PM
James_M's Avatar
I have checked for play in the ujoints and didn't feel anything. Could they still bed bad?
Also, don't havejack stands or anywhere to do that at it I did.
Old Oct 19, 2010 | 08:24 PM
94cummins diesel's Avatar
100 bucks says heat shield check that out on the exhaust or up by the fire wall by the back of the exhaust
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
gator515
Jan 14, 2015 01:56 PM
6btf350cummins
Dec 16, 2014 07:23 AM
Oct 31, 2014 08:10 AM
mule97
Oct 5, 2014 09:54 AM
