1995 f 250 7.3 PSD won't start in 40 degree weather. Low Oil pressure
Old Oct 16, 2010 | 12:05 PM
jerreber's Avatar
Default 1995 f 250 7.3 PSD won't start in 40 degree weather. Low Oil pressure
my 95 7.3 powerstroke takes a long time to start even when plugged in. Have to cycle glow plugs about 20 times before it turns over. Also, oil pressure is non existent on the gauge. At first I thought I would just replace the glow plugs and relay but I'm thinking it could be either the low oil presure or high pressure oil pumps? My mechanic is going to look at it tomorrow. He said it could be glo plugs, relay, hpop, lpop. Then he mentioned maybe the engine needs a rebuild? It does have 214,000 mile on it. When I start it it spits out ALOT of white smoke but once it's running the smoke disappears and runs smooth from the start. You can let it set for 4 or 5 hours and it will start right up just not in the morning with 40 degree temps or even 50 degree temps for that matter. Started fine all summer. Guess I'm concerned about it needing a rebuild. If that were the case, wouldnt I have black smoke spitting continuing after I start it. Also, if the lopp or the hpop needs replacing, is it a fairly easy and inexpensive fix? the mechanic said if the pressure test comes out normal, it could be bad injectors? Guess I should just wait a couple of days for the results but I'm freakin out!!! One more thing, I'm burning, 1/2 quart a week of oil with no visible leaks anywhere. Just bought the truck this spring from a friend and he said the batteries were a year old. Maybe I'm not getting enough juice to turn over but not sure that is really the case here.
Read more: https://www.dieselbombers.com/diesel...#ixzz12Xgb147N
Old Oct 18, 2010 | 08:50 PM
fordornothing's Avatar
could be the gp relay. or a fuseable link. if your lpop is bad. pull the engine and turn it over. then might as well rebuild it while it's out. hpop is on top in the valley. not exactly hard. just time consuming. mine is that way but i know it's just the gp relay...
Old Oct 19, 2010 | 11:56 PM
jerreber's Avatar
rebuild the engine??!!!! glow plugs and gpr all check out fine. need to pressure test the lpop and see what happens.
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
Ruddedawg5.9
Mar 1, 2015 09:16 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
