starving for fuel
Old Oct 7, 2010 | 09:32 PM
CorpusChristideisel's Avatar
Default starving for fuel
need help have a 92 1st gen cummins replaced head gasket and now have to floor it to keep it at idle i have bled all the lines from lift pump to injectors could it be the lift pump not pushing enough fuel
Old Oct 8, 2010 | 10:47 PM
the_new_kid's Avatar
Did you have the IP apart for any reason or take the throttle linkage off when doing the head gasket? I have had this happen on my 4bt when I changed the GOV spring and it slipped off the arm and once I figured that out I lost the timing for the throttle linkage. Once those were fixed it ran good.
Old Oct 9, 2010 | 04:10 AM
no the ip sayed intacked but i did figure it out it was my return line causing all the issues running fine know thanks for the idea
