No Power, Need Help
Old Oct 5, 2010 | 07:10 PM
crazycarl's Avatar
Default No Power, Need Help
Howdy Boys,
I have a 01 7.3 with 227,000. I started the old girl up and was heading to work and noticed a large loss of power! I noticed instead of hearing the turbo whine I can only hear an air rushing noise from under the floor under the dash. I checked to make sure all of the intake tubes are hooked up adn that the exaust is not cracked, all of the clamps look good and no oil leaks noticed around the turbo. I am thinking the waste gate may be stuck opan but i can move the rod from the soleniod by hand. I am not sure how to test the waste gate system properly, Mabey its not even the waste gate I dont know. Any help or information on how the system operates would be appreciated. thanks guys.
Old Oct 7, 2010 | 07:22 PM
crazycarl's Avatar
Howdy,
Well I think I found the problem. The pipes from the exhaust manifold to the turbo are leaking i am going to replace them and see if that is the problem. any ideas if I should use stock pipes or are there better pipes available in the aftermarket. Everything alse is stock, turbo, manifolds, ect...
Old Oct 8, 2010 | 12:31 AM
CSIPSD's Avatar
You can get bellowed pipes from IH... There a bit better...
I dont believe that is your MAIN problem. If there leaking they need to be repaired, but it sounds like your EBPV (Exhaust Back Pressure Valve) is closing while you drive. This can happen when the cold weather comes in, and also when the EBP sensor gets plugged. There is a plug on the bottom of the turbo pedistal at the front, unplug it for a day or two and see if most of your problem goes away or not...
Old Oct 9, 2010 | 02:29 PM
crazycarl's Avatar
I will give it a shot. I ordered the pipes and they will be here monday so I will unplug it for the weekend and see what happens. I was planning on cleaning all the moving parts of the turbo as long as I have to remove it any way so if it is plugged hopefully I will see it. Do you recomend any type of cleaner or is there any chemicals I should stay away from?
I disconected what i think is the conector for ebp. a small two wire conector at the front of the turbo, there is a metal spring type latch holding it in. I will see what happens.
Old Oct 12, 2010 | 08:37 PM
crazycarl's Avatar
Howdy boys,
Well I have the turbo and am lookinh at the pedastle and trying to figure out if there is anything I should be cleaning that I cant see or if I should pull the pedastastle out of here any Ideas to help the ebp thing work properly when I get her back together would be much appreciated. thanks guys.
oh ya disconecting the ebp conector has made a diffrence, do I need a new soleniod?
Old Oct 12, 2010 | 09:09 PM
wantpower's Avatar
i had to replace my sensor and clean the tube it is on front of the motor above the water pump guzzies has a web on it thats where i got my instructions
Old Oct 13, 2010 | 10:25 PM
crazycarl's Avatar
howdy,
What did you use to clean the tube? Was it obvious that it was plugged or did you try to pass somthing through it because mine looks clean from what I can see? Is there a port in the plenam were the tube enters that needs to be cleaned as well. thanks
Old Oct 14, 2010 | 09:52 PM
wantpower's Avatar
i used break cleaner and small air compressor to blow through the tube take the sensor off and clean through the bracket dont stick nothing in the sensor though dont wanna take a chance on damaging it it helped mine out
Old Oct 15, 2010 | 06:35 PM
crazycarl's Avatar
thanks I cleaned it up we will see what happens.
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
