Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
no power to amp suddely
Old Oct 2, 2010 | 10:23 PM
wyodiesel92's Avatar
Default no power to amp suddely
Mtx 250 monoblock amp. Just installed, tried connections in accesory, started the truck and no power, no blown fuses. Wtf
Old Oct 2, 2010 | 10:26 PM
Captain Call's Avatar
check the remote wire
Old Oct 2, 2010 | 10:50 PM
Already did and its fine
Old Oct 6, 2010 | 06:55 PM
Pulled out the multi meter and looks like its a problem with the head unit. And of course the one year warranty is up on it so looks like I'm going to have to wait to get a head unit, everything but front speakers work on radio so ill just have to live with only radio till money comes up
Old Oct 7, 2010 | 09:12 AM
AdrianD's Avatar
If you don't have voltage on the remote wire with the head unit on you can wire from the ignition to the amp's remote terminal, add a switch and turn on the amp whenever you want
Are you positive you didn't check the power antenna wire ? Had that happen to me once, amps only worked when radio was selected. Switched to CD and they shut off.
Old Oct 12, 2010 | 01:13 PM
Ill double check, still not sure about the speakers and tweater up front though
Old Nov 15, 2010 | 10:53 PM
barkrulz's Avatar
I have a problem with my kenwood nav not kicking on the amp on occasion. found that if i turn the key to the on position then back one click and back to on, wait for minimaxx to initialize then start, it comes on every time. No idea why it does this but it works everytime. i'm so used to doing it that i do it automatically now.
Old Nov 16, 2010 | 07:21 PM
dmaxtothemax's Avatar
How secure is your ground wire on your amp to frame? Usually 6-18" long is best... I try to make my ground the largest wire connected to the equipment just to satisfy me...
On the other hand, if your remote wire is not showing amps (miliamps), then that could also be your problem like stated above... use your ground wire (once it's been proven secure to frame) and your remote to test your amperage... it will be very low - ive been out of it too long... Probably show as mili-amps...
If no amps, then work back to the head unit... if amps then you have another problem...
I would start with the ground wire tho... Nothing will be stable and sometimes won't work without a good solid ground connection...
May 10, 2015 10:57 PM
CumminsCoalRoller24/7
Mar 8, 2015 09:14 PM
