Have fuel and glow plugs are working why wont it start
Old Oct 2, 2010 | 03:59 PM
Jeff Davis's Avatar
Default Have fuel and glow plugs are working why wont it start
My 7.3 ran fine and it started getting bad gas milage my suspicion was faulty injector before i parked it I noticed when starting it, it acted like the batteries were going bad just before it would fire. So I parrked it for a week or two and went out to work on it and it won't do anything but crank over no start. I have fuel and checked the glo plug as well as the relay what am I missing. (also tried a couple shots of ether not a pop fart snort nothing) also saw the internet dangers of ether in diesels and that experiment is over. Need help
Old Oct 2, 2010 | 06:34 PM
Lange503's Avatar
have you replaced the CPS? (Cam Position Sensor) they are only like 30 bucks its worth a try if you havent yet
Old Oct 3, 2010 | 10:52 AM
Jeff Davis's Avatar
Just got done replacing it 30 min ago no change in situation think I going to attack the HPOP next. Finally got a pop out of it when I gave it a whiff of starting fluid in the correct intake tube ( sometimes I am an idiot) or is there another sensor that can effect the injectors from opening.
Well I am known to always over look things and get to far in depth with situations and Jeff stricks again lets reflect on what the first symtoms were "BATTERIES" seem like they were going dead just before fireing, so Jeff decided to take two weeks and disasemble his engine look for injector problems and oil distribution problem and glow plug problems and wiring problems and cam position sensors, wouldn't you known Jeff decided to use two cars and hook up jumper cables to both batteries and WALA fired right up it was the batteries. Truck seemed like it was cranking over normally but I guess it wasn't Thanks Lange503 for the input it's always nice to hear a reply before people like me take a 20lbs sledge to it and really fix it. Sure that I still have problem with it somewhere because of the gas milage but at least I can move forward with diagnoses of the injectors with it running
Old Oct 3, 2010 | 11:03 PM
Lange503's Avatar
yeah i tend to over think about everything i do LOL glad its up and goin though, as for the mileage... check your fuel filter, and how long has it been since the oil has been changed
Old Oct 4, 2010 | 11:30 AM
CSIPSD's Avatar
These trucks REQUIRE a solid power source to crank and start. Just because they will crank does not mean there is enough power to fire the IDM...
And NEVER... NEVER use starting fluid of any kind on a glow plugged diesel unless the glow plugs are disconnected. You can and will damage the valve train!!!
Old Oct 4, 2010 | 03:53 PM
Diezel Dawg's Avatar
MAybe you have an excessive draw in your starter. I would start with batteries then work your way to the starter if the batteries check out
Old Oct 5, 2010 | 02:44 PM
Jeff Davis's Avatar
I have only own it for two years and put 12000 miles on it (131000 bought and 143000 now) changed the oil 3 times and the fuel filter twice had a rear disc metal to metal couldn't hear it with the noise of the engine, changed out the rotor and pads seems to be coasting alot better than it was maybe the problem with mpg possibly
Old Oct 5, 2010 | 03:05 PM
Lange503's Avatar
very well could have been? what oil are you runnin?
Old Oct 5, 2010 | 04:10 PM
Jeff Davis's Avatar
15w-40 rotella first two times and 15w-40 Delo 400 last time average temp casa grande in summer is 107-115 winter 70-85 is this a good weight for these conditions also there is signs of oil in the intercooler tubes ( two steel tubes that circle around the radiator I think that's the name for them) not much but tiny puddles at the rubber connection clamps is this a bad sign .
Old Oct 5, 2010 | 11:21 PM
Kyle_KleinSS's Avatar
Look into the ccv mod. Thats what the oil is from
