Down pipe for HX35
Old Sep 17, 2010 | 06:10 PM
Dirt_Diver's Avatar
Default Down pipe for HX35
I was just curious, if there a way you can make a 5'' down pipe? Thanks
Old Sep 17, 2010 | 06:17 PM
RAW's Avatar
RAW
I don't thinks there are any available. Making one would be tight, very tight. A 4" is tight enough. You may be able to make one, be very custom and precise though. Personally, I don't think there wold be any gain.
Old Sep 17, 2010 | 11:12 PM
FastCR's Avatar
it could be done, its a matter of clearances. I'd stick with 4". Generally you don't even get any gain from a 4 to 5" exhaust, I wouldn't worry about just the downpipe.
Old Sep 18, 2010 | 10:26 PM
torqctd's Avatar
3.5" to 4" is only a small gain.
Old Sep 19, 2010 | 12:50 PM
Dallas Flywheels's Avatar
Not worth the hassle to go to 5 inch. Four is easier to do.
Old Sep 19, 2010 | 03:53 PM
Dirt_Diver's Avatar
Thanks guys! Ive got the pipe welded and ready to stick on. Since i dont have a pipe bender, would it be ok to cut a 45' degree angle in both side pipes like a picture frame and weld them together or would that cause more back pressure?
Old Sep 24, 2010 | 12:18 AM
torqctd's Avatar
You would then be putting "restriction" back into the air flow......better to go with a 4" "bent" tube.....or just leave it alone.
PowerstrokeDepew
99-03 7.3L Performance
May 5, 2016 08:12 PM
Devon7.3
Sep 28, 2015 09:30 PM
Blake35
Jul 25, 2015 03:44 PM
ebg2g
Mar 29, 2015 06:15 PM
greasesheik
Dec 13, 2014 06:55 AM
